List The Stuff You Guys Are Going To Be Selling At Scottfest 2011
    Anything in the bazaar, and I have a '90 TC fan shroud/bottle some one can have for 15 dolla
      I'll have full J-mods available and ready for install. For AODE, 4R70W and 4R75W transmissions.
      08 Lincoln Navigator L - 233k
      03 Mercury Marauder- 63k
        I vant vone!
        I am also bringing a 92 brake booster for 1980c10..
          Originally posted by P72Ford View Post
          -Oil Pressure, Water Temp, Volt gauges. Stewart Warner.
          -Pioneer subs and amps
          If people want me to bring stuff, you better let me know. .
          Bring me the gages, and if you get me model numbers on the amps, I may want one depending what it is.
            Yeah...And I am still ready to pay for the headlamps.
              Originally posted by Grand_Marquis_GT View Post
              .... a torino console/shifter as well.
              What year? Stick or Auto?
                I will bring the amps (and subs) as well. If you have use for an amp or two, fine. Otherwise I will bring them back home.
                  1 infiniity 611a amp monoblock
                    Things I can bring:
                    -Chrome oil pan with oil level sender, could be cleaned to look new
                    -Timing cover, without mechanical fuel pump boss
                    -'Power By Ford' valvecovers. Stamped, some dents in them
                    -Vacuum soup can (the small one)
                    -SuperCoupe torque converter for the AOD
                    -'86 AOD valvebody with Transgo shift kit
                    -Stock transmission pan
                    -Complete stock hard transmission lines
                    -EFI lower intake
                    -Entire A/C system (not including lines); from an '87
                    -Extended O2 sensors
                    -Dip stick tube and dipstick. Was NOS
                    -Equus Tach. Small 2.625"
                    -ECM for SD HO swap
                    -Tripminder
                    -Hella upgraded headlamps
                    -Fuel pump
                    Things I would like to obtain:
                    -Clean/ mint set of trunk rugs that will fit my '87 Coupe
                    -Dash piece for the passenger's side of the dash (same car). The long wood grain trim piece with the vents in it
                    -Clean access panel that goes under the steering column, blue
                    -Anything NOS I could use. Grille, headlight doors, lenses, interior bits, etc. Clear lenses?
                    -Passenger's rear taillight housing/ fender extension
                    -Blue steering wheel without cruise buttons, preferably without the leather wrap
                    -Spare 140 speedometer
                    -Driver's side fender. Must be mint, new, NOS, etc
                    If people want me to bring stuff, you better let me know. I'll probably just end up bringing my pick-up truck again, so I could bring ALOT of stuff.
                    Well then, I have a speedometer for you too then mang. I'm gonna try to go to the junkyard this week and see if I can find some trunk carpeting for you. And that fuse panel cover as well.
                      also 140 speedo
                        Ill send anyone intetested in a jmod a pm later thos evening for details. It should be about $20 including install.
                          I'm bringing 12 quarts of AMSoil Mercon V for the swap. Think we could pull off the blood transfusion?
                            An 89 country Squire LX with a few mods.... for the right price- or a partial trade for a cheap pickup.
                              Does the 4r70w have a drain plug in torque converter?
                                I don't think my 4R75W does...
