First off let me introduce myself, as this is my first post on GMN.
My name is Blake and my daily driver is a 1994 Grand marquis LS, she's not in the best shape ever but has a super straight body and the biggest rust spot on it is about the size of a pin head so I would like to keep her running as well as possible.
Tomorrow I'm going to clean my EGR ports and throttle body (providing the weather is dry) and I can't seem to find the torque specs for the TB/upper plenum bolts in my haynes manual, so if anyone has those I would love to share in that knowledge.
Also I figured I might as well port the upper plenum while it's off and, being that I've never done anything of the sort before, I have a few questions:
Should I take it all the way out to the gasket? Would the expansion/compression of air from the throttle body through the upper plenum cause more turbulence than the small notch that would be there if I didn't bring it out and just cleaned up the molding imperfections?
I don't want to mess with it if it won't help, so I'd like to know the best procedure (if there is one).
Thanks in advance and I hope that you guys will be as much help with my GM as the guys at allpar were with my Imperial. </3 RIP ):
Even more than that; I hope I can help one of you one day (I know, it's unlikely...) Cheers!
