Cranks, no spark, coil not firing.
    Thanks! So I'm getting closer. I found in the book where it says 'rear of RH fender' with no illustration.
    Didn't have a lot of time last nite, had the grandkid, but I did putz around a little.
    I'm getting main power and trigger power at both relays (fuel and eec) but nothing out. Sure seems like a fried component or bad ground!
    When I get a chance I'm going to attempt to trace wires. I did notice that the EGR soleniod seems to have weak power out, the wires in to that assembly are ugly anyway so I'll head up to the JY and pull the whole thing off a pretty clean engine compartment MGM.
    I'll keep showing my ignorance, er I mean posting my experience and asking questions as events warrant.
    Pete
      Ground wires on the back of the fender on the passenger side, on a bracket. Small wires, with green colored bolts. 7mm or 1/4" iirc. Though that's not the main ground.
        Well, here's a thought then, to check this, put the key in run, and jump the S and the Batt terminals on the starter solenoid, if the ignition switch is the issue, the car should start.
        Except that the extra terminal is never used for anything .....
          What extra terminal?
          The S terminal is what activates the solenoid.
            I've checked most grounds under the hood. The only one I haven't seen is next to the drivers' horn, have to remove the wiper washer resevoir to check it.
            I suspect I've got a broken wire or bad electrical bit that's keeping the circuit open. I'm sure with another 100 manhours I'll find it
            On my 85 there's a wire coming off both little terminals on the soleniod. Perhaps it's a CFI thing.
            Pete
              did you look for mouse damage?
                except on CFI and Duraspark vehicles. Ignition power comes from there while the engine is cranking.
                  Funny you should say that, it makes sense why my old harness killed computers. It had a wire attached to that terminal...
                    your 86 harness had an I wire ? new one on me.
                      Yes sir, it does. I'll look at the remnants and see if I can find where that wire went.
                        well, if it went to the stock locations, it really has nothing to do with the ecm. it only feeds power to the coil. the single wire stuff has a tap off the S circuit wire and a diode to power the ignition when cranking. The older ones that use the I terminal are electrically the same but the diode is inside the starter relay instead of in a rubber blob in the wiring harness. Now if the wire wasn't stock and went to some strange location, who knows.
                          Also, when I first had it, the starter solenoid was the old style...
                            OK, I poked around for rodent damage, nothing obvious. Good for the mouse too, I would've caught that bastid and dropped him off at a gay massage parlor lol.
                            I really haven't had a chunk of time for this last couple days. I should be hitting the problem Sat am and hopefully report some good news.
                            Pete
                              Maybe some Duraspark vehicles ... mine that came with DSII had nothing on the extra post. I can't comment on CFI, though. Is the idea that the extra post is just connected to the other one, so that when the starter is energized the extra post can be used to automatically do something else?
                                Yeah, it's like a double throw relay basically. When the solenoid is energized, both of those terminals (the one going to the starter, and the 'I' terminal) will both have power.
