View Post
A/C O-rings
Still haven't had time to work on the a/c much, but today I broke out the gauge kit (harbor freight POS, I believe) just to take some measurements. Had a bit of trouble with the fittings on it, got the low side fitting to go on with a bit of wiggling, but when I tried to put the high side on it broke the valve. Now if I take the cap off it slowly releases gas (I can hear it hissing).
Here's the thing though; It was built in '94 (post r12 ban, correct?) and seems to be a factory r134a setup, (doesn't appear to be one of the retrofit kits sold at advance anyway) so to the best of my knowledge the valve itself can't be replaced (kinda looks similar to a retrofit, but the valve doesn't have a "bolt head" type of shape)
Supposing I can get it off with a pair of pliers, can I even get the individual part, or would I have to buy the whole hose? If the retrofit valve fits, would it work? (I already have one that never made it onto my last car)
Originally posted by eightball200 View PostStill haven't had time to work on the a/c much, but today I broke out the gauge kit (harbor freight POS, I believe) just to take some measurements. Had a bit of trouble with the fittings on it, got the low side fitting to go on with a bit of wiggling, but when I tried to put the high side on it broke the valve. Now if I take the cap off it slowly releases gas (I can hear it hissing).
You probably pushed the schrader valve on the high side off center so now it's leaking.
You should be able to replace the valve inside by using a valve stem insert puller, or really small needle nose pliers or something along those lines.
OK. I think I need to use some other gauges tho, these don't even appear to fit on the high side >:-[. Any idea how much the valve is at the dealer? Checked at napa today and they couldn't find it.
Anyway, I just found out I have access to a heating/air manual (haynes). This one has lots of info, procedures, and capacities for may different vehicles (up to '99). Quite detailed. If anyone wants a specific bit of info, tell me and I'll see what I can find. It's the least I could do for all the help you guys are giving me.
my HF 134a gauges fit OK, but they definitely aren't the best quality.86 Lincoln Town Car (Galactica).
Hmmm. The ones I have take a bit of wiggling to fit the low side and won't go on the high side at all. Tried it on a retrofit valve I had laying around and doesn't fit that either. Just doesn't seat all the way. Is there anywhere that sells JUST the fittings? I really don't want to have to buy a whole new set.
