Kiss of Death
    Heaviest part of the door is the window next the window motor.
      I seem to recall you using really thin oil. Did you try anything heavier after the noises started?
        Just a small update. Pulled the #8 spark plug. this was the one that looked like detonation and i replaced with a new plug. It was bent and contacting the electrode. It also had scrapes on it. It appears #8 piston is coming up too high and hitting the spark plug. It should be safe to assume that the piston has contacted one or both valves, possibly damaging the head. So there is probably damage from the crank to the head on #8.
          Had been using Rotella.
            Originally posted by P72Ford View Post
            Too bad you're in TX. I'd like to have the doors off that car.
            Both doors are rusted at the bottom and the weld has separated from the inner and outer skin. This is one of the reasons i have decided to move on since no after market 2-doors are available and rare to come buy used. Would sell them for $50 each.
              Originally posted by 79lincolnlover View Post
              What will your replacement toy be??
              My wife has been hinting for awhile for a tri-five chevy. Personally i would like a newer mustang or one of the new challengers. So right now nothing anytime soon.
                Not to start anything but I own a NOS door and it is still a heavy fucker and I am no small guy either.
                  I wouldnt let that stop me. It going to happen to mine evetually. I will weld and or make the pieces needed. You should see some of the cars people start with. One dosent find doors for a 55 Pontiac Star Chef let alone fenders rear sections....
                    do you have a pic of the nitrous setup on your motor? many pics would be nice
                      full throttle switch
                      nitrous plate under carb
                      solenoids and fuel supply
                        Have removed most of the performance parts to sell. All that is left are the heads. Will see if they are damaged. If not, will sell those also. Will part out the rest of the car, and when i get tired of looking at it will take it to scrap.
