4.6 PI Motor Swap With OBD-I Setup 1992-2000
    I really wish I had some of that non-adhesive tape that Ford uses on their harness assemblies.
    I wonder if you could buy that from Ford?
      I've found it online, but that doesn't help me right now here today. The only thing its really used for is a wrap over the split loom, so I may just build the harness, order the tape, and wrap it next week.
        How much does it go for?
          I'd be fine with just the loom... just so ya know.
            well without the over-wrap, the sections of loom will not stay together neatly.
            Harness is done, except for looming and such. Don't have the materials here right now, so the looming will have to wait. TPS and crank sensor plugs were changed to 2003 types. I did the COP wiring by partially re-pinning the connector so as to minimize the splices. Its got 4 splices now instead of 8.
              just gimme a cheat sheet to help keep track of the mods in case I do ever sell this car or need to work on it later (probably the latter).
                Is it soup yet?
                  needs plumbing and loom.
                    Hurry up and finish so I can do mine. Gosh.
                    lolz.
                    08 Lincoln Navigator L - 233k
                    03 Mercury Marauder- 63k
                      COP wiring is actually per that article you linked, but instead of splicing the colored wires to existing stuff coming out of the fat square plug, I pulled the entire length of wire out of the plug and replaced it. The originals were tan with different color stripes, not the colors listed. Pretty sure the wires out of the 03 harness match what was posted though. I've got scribbly notes that I'll translate to something coherant to other people next I have that notebook in my hands. Its at Scott's. Basically instead of 8 splices, its got 4. Two are on the driver's side, roughly about the #7 plug, the other two are approximately center behind the engine. Splice for the 03 crank trigger is down near the crank trigger, splice for the 03 TPS is also roughly center behind the motor. ECT wiring is extended, 2 splices in that one, one in the loom near the #6 plug, and another about 4" from the ECT connector. IAC splice is in the pair of wires feeding it. IAC, TPS COP and crank sensors are 2003 parts, everything else is 1993.
                      There are 2 unused sensors that have no connections, though if you're into that stealth thing I can whack the connectors out of the 03 harness and tape them into the 93 harness so it looks like they do something. One is the knock sensor, the other is the cylinder head temperature sensor down there on the left bank cyl head.
                        nah... leave them hanging "neatly". If I ever do the horrible bastard change over (OBDII) I'll need them still there. Probably not, but it is possible that I'll do it.
                          OOH. OBD-II swap.
                            eeewwww OBD2 swap.
                              waiting on hoses, dont trust the 93 originals
                                eeewwww OBD2 swap.
                                yeah... possibility is remote... but it might happen... much further down the line.
