4.6 PI Motor Swap With OBD-I Setup 1992-2000
    So is this simply something that can be swapped out to a compatible one without excessive bother?
      gotta drop the trans pan... but it's immediately accessible. PDF showing location
      Ford part number for the solenoid needed is F5AZ7G136A
      Rock Auto has an Airtex/Wells exact match and a Standard Motor generic that is built better (more metal).
      FordParts.com has it for $54.80 (almost double).
        Are the two solenoids physically interchangeable between the two transmissions?
          If its just a pop and swap thing, no big deal. probably can get it from the Ford dealer over the mountain easy enough. They came pretty darn close in price with that AC compressor I bought, and by the time I figured in shipping it wouldn't have saved me any real amount of money to order it online.
            yeah... it's a pop and swap for 92-97 or 98 model years. Later models used a different connection though it was physically the same solenoid as the later aeros.
              So what part does it need, the F7AP-7G136-AA for a 1996 Vic ?
                edited that post up there...
                part number is F5AZ7G136A
                that linked PDF also has the part numbers.
                  Scott is looking into ordering the part from that Ford dealer so they'll actually have it by Friday.
                  Probably be a good idea for y'all to talk about it so there's not 2 ordered.
                    looks like its a simple matter of dropping the pan and maybe the filter to get at the solenoid. I suppose it looks like a trip to the store for at least a trans service kit. Hey Jason, do you happen to know what fluid is in there currently, and how old it is? If its fairly recent I won't bother draining the converter but if its due for a service anyway I guess I'll pick up more fluid.
                      Scott's got it covered.
                        One step forward, two backwards. Starter circuit is wired up. New relay fitted into the existing fuse/relay box under the hood and powered as it would have been on an 01. Its tapped off fuse #2, which is what would have fed power to the starter solenoid anyway on the 93. Also got the reverse lights working, simple matter of finding a wire that I missed and plugging it in.
                        Now for the backwards. It won't run anymore. Fuel pump does not engage, and it has no injector pulse or ignition pulse. Crank sensor ohms out fine all the way back to the ECM. ECM seems to be making this faint high pitch whine noise that I do not recall previously. The only thing I can come up with here is when I tried to start it a few times before the battery had charged sufficiently, it somehow spiked the ECM and killed it. I don't have a spare to verify so thats it for tonight I guess. I guess next week its back up here, to the yard for an ECM, and try again.
                          Ha I had done a full 2004 PI engine swap in my 96 town car, fired up first try
                          Epic threads here
                          http://www.crownvic.net/ubbthreads/u...ue#Post2169782
                          Victory thread
                          http://www.crownvic.net/ubbthreads/u...ue#Post2182043
                          Morals of the story
                          You need to convert the car over to 96-97 style configuration for Intake, throttle cable, EGR bla Bla I started with a 96 to make this all good from the git go..
                          OBD 1 not deal breaker but you CANT re-use the 96-97 harness and this leads to the golden rule
                          KEEP THE FUCKING PCM FROM THE CAR INTACT. Swap as many of the ORIGINAL SENSORS AND SHIT FROM THE CAR TRASH ALL THE SHIT FROM THE ENGINE
                          This is all you want from the new engine just the long block and Intake
                          Pulled the original 96 engine harness marked up all the connections, it went back on the PI engine just dandy used all the 96 sensors and injectors.
                          ONE EXCEPTION is the 92-2000 MAF is shit, use one from a 2001 up with a PI engine
                          96 MAF blocks off much airflow, many have reported a stock PI engine pegging one of these
                          01 up PI style MAF
                          Car still runs fine with the stock 96 PCM and stock tune with the 01 PI MAF, ran a 16 flat on the stock open 3.27 rear and dual exhaust (the 96 was a Touring edition aka a HPP with the Sunroof, Compass and Auto dim mirrors and the JBL audio)
                          Here are enough pictures to make your asshole pucker
                          http://s348.photobucket.com/albums/q...Engine%20Swap/
                          2004 Marauder M79 90K miles Jmod!! 14.85 @95.63
                          2004 Crown Vic LX 135K Silver Birch Light flint leather FMX1 04 P-71 PCM swap 04 P-71 Airbox and Zip tube "$100 MZT" 01 F-250 70 MM TB 21mm swaybar wood steering wheel BH headlight relay
                            Good info Frank.... you must be bored at work, since you revived a thread from July.
                            The car in question Left Scott's shop in PA and made back to Texas under its own power some time in August. you can read the rest of the story here;
                            http://www.grandmarq.net/vb/showthre...anthers/page12 start at post #233.
                              i followed your thread chevyguy, but it would not run on the 93 stuff, ran fine wot but had a #7 misfire at part throttle........we ended up doing an obd2 conversion and now all is well!
                                I am more than glad I did not try this with my EEC-IV powered 94 instead... Though a few have lived to tell the tales of the conversion on the EEC-IV cars Plus with the Wixom built 91-94 town car they already have a DPFE which is one potential hurdle for converting the 92-94 STAP models with the lowly PFE system.
                                More power to ya to do the EEC-V swap. I do remember your tales of agony with the swap now!!
