The long-awaited "How do I put bucket seats in my Panther?" thread!
    Unfortunately, the short of it is that I don't have a really good answer, so the best I can offer is to share my experiences and frustrations. NB: My cars have all been pre-1990, which is the year in which the floorpans are said to have been changed, so any advice from me only applies directly to model years 1979 to 1989.
    Anywhoo.
    The most convenient solution is obviously to get a set of Box fleet-package (mine is a P72) bucket seat assemblies and bolt them in. This works perfect for a four-door, and for a two-door the quick fix would be to leave out the bolt that secures the seatback so you can fold them forward. Unfortunately, the stupid things seem to be outrageously hard to get hold of. Probably somewhat related to reports that lots of agencies liked to rip them out in favor of split benches! And of course, if you already have a roadworthy P72, you probably want to keep those nice P72 buckets in your P72.
    You can get a set of bucket seats from another vehicle. I have an ugly tweed set from a '96 Mustang. The problem? The seat-to-slider bolt pattern is about 1.5" narrower than your stock split bench! So, if you have a complete set of four manual split-bench sliders (full bench sliders were the same, I have one pair from each), you can drill extra slider-to-floor mounting holes about 3/4" outboard of the originals, and bolt your bucket seats right up. Of course, I noticed that this didn't let the seat go far enough backward, so I took advantage of the SN95 seats' extra rear mounting holes, drilled extra mounting holes in the front end of the slider tops, and used that to move the seats back a bit. Oh, and you'll want to use some spacers because the bench-seat sliders are curved and the bucket-seat frames aren't.
    So, now you've got your bucket seats bolted into your Box-body, except that now your head scrapes the roof and the steering wheel is annoyingly low in your lap and it just feels all wrong. This is where I noticed something very interesting about the P72 bucket sliders - in addition to the slider-to-seat bolt pattern being basically the same as the Mustang seats, they're an inch or two shorter vertically than the bench sliders! Since I do own an '87 P72 with buckets, and got completely fed up with sitting too high after putting the SN95 seats in my '81 LTD, my quick fix was to steal one set of sliders from my P72. This makes for an acceptable driving position, and since my usual passengers are at most 5'2", it'll work OK for me for the time being.
    But what if you don't like sitting too high and don't have access to P72 sliders? That's led me to search for other applications that may have used sliders that were the same as or similar to P72 manual sliders. The D8 part number I found on my P72 seats seems to suggest that the whole assembly may have been in use before Panthers were on the market. And since I've sat in and driven around the block in a '78 Mustang II King Cobra, I can recall that those seats were pretty doggone similar, except of course for the fact that they were designed from the factory to fold forward. Also, a handful of Panther fans seem to be of the opinion that P72 buckets assemblies were shared more or less with those from Fairmonts. So those might seem to make two possible models to steal seats and/or sliders from. And though I've not been in a bucket-seat Granada, Granada buckets appear to be more than a little similar to P72 buckets, so they might be a possibility as well.
    Now, I have since discovered that Mustang IIs used the stud-affixed-to-the-slider method of attaching the slider to the floor, and an indulgent eBayer measured his mounting pattern and confirmed it to be both too short and too narrow for a Box Panther - 14" by 14" IIRC. However, staring at pictures has almost convinced me that if you cut off the studs and drill mounting holes, Mustang II sliders might be found to be functionally interchangable with P72 sliders. I unfortunately haven't yet contrived to measure a set in person.
    As for getting sliders from a Fairmont, that at first seemed as though it might account for the weird fact of P72 sliders getting an extra set of mounting holes, each about 3/4" inboard of the ones actually used in the car. My only concrete info so far is from another eBayer who measured a Fairmont being prepared for the 24 Hours of Lemons who had just the seat back panels up for sale, which looked interchangeable with mine. However, he reported a slider-to-floor mounting pattern of 14-1/2" by 10-3/4", which is exactly the same as that of the SN95 sliders I already have in my possession. So unless some Fairmonts used very different floorpans from his, Fairmont sliders would appear to be no use at all.
    Of course, all this is no use at all if you want to use power sliders! My experiment with Box-Panther split bench power sliders from several years ago involved bolting a piece of 1/8" bar stock across each end of the top of the slider, and drilling extra holes in the seat frame, inboard of the factory holes, to attach the seat to the bar stock. One obvious problem with this is that it adds height to an assembly which, as with the manual split-bench sliders, really doesn't need extra height added to it. I may try another experiment to see whether it's practical to just drill extra seat-to-slider mounting holes, but that depends on there being sufficient material approx. 3/4" inboard of the originals.
    My other obvious option for a power slider, would seem to involve very annoying modifications to the SN95 slider in my possession. Absolutely no clue at this point how easily that can be made to work except by someone with the "skillz" to just make split-bench manual sliders shorter in the first place. Which I may or may not have. Though, one user mentioned that he'd gained extra leg room on his completely stock seat assembly by just bolting bits of bar stock to the floor and attaching the stock slider to that. So maybe that could yet be a feasible way to adapt a wrong-bolt-pattern slider to the Box Panther floorpan. I may just have to try it and find out!
    Something interesting I just noticed. This is supposedly a front seat from a '98-up Town Car. I assume slider mods would be needed ... no clue at all, of course, on what Box sliders might bolt up, and it definitely wouldn't be a convenient bolt-in on a two-door like my '81 ....
    I also didn't mention the concept of using late-model P71 seats or sliders. I'm expecting to see Nathan in MI soon, so I may ask for permission to measure his '01 P71 seat assemblies. I will note that my initial impression is that the seats themselves are a good deal less comfortable than my P72 seats, but that's all I know for sure so far other than that as of '04 P71s could be had with zillion-way power seats.
      I was thinking of making adapters out of thin steel after I find a passenger side slider for my 85 coupe, I looked all over the yard and none of the boxes have electric sliders.
        Yes, the P72 buckets are VERY comfy. I loved mine...
          If I may add a bit to this.
          I experimented with 65 mustang low back buckets in a box wagon (79-89 floorpan)
          The seat isn't a direct bolt up, but it's close enough that it should be easy to drill out.
          I didn't want to modify my seats, so I was going to just run flat bar stock across the base and use it as an adapter.
          In the end someone wanted the car worse than I did, so I sold it, but kept my seat and power seat frame.
          I don't know how early mustang seats are on a long drive, but they seem super comfy on short trips.
          If only they came stock in cloth instead of vinyl, I'd have them in the HillbillySUV right now.
          Axle codes
          Open/Lock/Ratio #
          G / H / 2.26
          B / C / 2.47
          8 / M / 2.73
          7 / - / 3.07
          Y / Z / 3.08
          4 / D / 3.42
          F / R / 3.45
          5 / E / 3.27
          6 / W / 3.73
          2 / K / 3.55
          A / - / 3.63
          J / - / 3.85
            So you experimented with modifying first-gen Mustang sliders to fit your floorpan, or bolting first-gen seats to your sliders? I'd expect the seat-to-slider bolt pattern might well be the same as MII, P72, and SN95 seats ... and presumably Torninos, Cougars, and any number of other ancient Fords with bucket seats.
            One thing first-gen seats have going for them, is that it's easy (if expensive) to buy brandy new cushions and covers for them, and the ones I've seen have that nifty feature of the seat backs tilting slightly inboard as they fold forward. From my perspective, I rode shotgun in a '68 and hated the seat about as much as the slab-flat ones in Nate's P71, while dropping into a '78 King Cobra seat I loved it instantly.
              I put a 1st gen mustang seat on an 88 panther power seat slider. It's not a direct bolt up, but it's an easy mod to make them fit.
              Just line things up. make some marks, drill new holes in the seat base, and thru-bolt everything together.
              As for seat comfort, I've always found the 65 mustang seats super comfy. Then again I've never gone on a road trip in anything with them.
              Unlike a lot of folks, low back seats just feel right to me somehow. so maybe I'm biased.
              Axle codes
              Open/Lock/Ratio #
              G / H / 2.26
              B / C / 2.47
              8 / M / 2.73
              7 / - / 3.07
              Y / Z / 3.08
              4 / D / 3.42
              F / R / 3.45
              5 / E / 3.27
              6 / W / 3.73
              2 / K / 3.55
              A / - / 3.63
              J / - / 3.85
                So it didn't put you up too high like these dumb late-model seats do?
                  You've got to remember this was well over a year ago, so I'm a bit fuzzy on specifics, but I seem to recall thinking it was easier to get in and out.
                  One of my big all time gripes about panthers is the high seats and low roof line. I'm average height and I still bang my head getting in now and then. If anything it might have been a bit closer to or further from the wheel than a stock seat.
                  I've still got the seat and frame in my building. I could set it on there and measure the distance from the front mounting bolt (stock location) to the point where the seat bottom and seat back meet.
                  If anyone is coming through this way I'll make you a good deal on two 65 mustang low back buckets, in need of new upholstery (seat buns are ok) and a panther power seat frame.
                  Axle codes
                  Open/Lock/Ratio #
                  G / H / 2.26
                  B / C / 2.47
                  8 / M / 2.73
                  7 / - / 3.07
                  Y / Z / 3.08
                  4 / D / 3.42
                  F / R / 3.45
                  5 / E / 3.27
                  6 / W / 3.73
                  2 / K / 3.55
                  A / - / 3.63
                  J / - / 3.85
                    If I remember correctly, the floor pan from 90-95 or 97 is the same so the aero P71 buckets should be a direct bolt in and are pleantyfull, at least here in FL.
                    1991 LTD P72 351 W Restored Century Police (Ongoing Project) Sergeant Vic.
                    It's a dog eat dog world and I'm wearing milk bone underwear.
                      If you're interested I have a set of Mustang II sliders you can have for the cost of shipping if you want to experiment. I've owned quite a few II's over the years and there are a set hanging in my garage. Alternatively I can measure them up if you want to just know how long/wide/tall the whole set-up is.
                      sigpic1989 Mercury Grand Marquis LS
                        Easiest conversion is to get the seats, take your sliders off and swap them to the new seats, they should bolt right in after that....
                        Also, the older Police package seats are the same as the 1990 - 1991 Taurus... MANUAL seats, the electric ones are different, and won't bolt in.
