Results 1 to 7 of 7
Thread: Universal Body mount adaptor washers specs?
    WARNING DON'T DERP AND DRIVE!
    Jul 2006
    'Cada Oregon
    4,682
    Question Universal Body mount adaptor washers specs?
    I got two boxes that need new body mounts and I was thinking of trying to make the washers myself to save a few bucks I need the specs for those neato washers that make everything possible...or perhaps buying a couple washers or something?
    39,554
    don't have the numbers, but I can tell you how to get them. Measure the step on the ES bushing where it would go through the hole. Measure the actual hole. Thats your ID and OD of the washer, with a few thou allowed for fitment. These would be vastly easier to make with a lathe, but i guess you could do it by hand with a die grinder for the inside, and a bench grinder or whatever for the outside rough diameters, then file fit to make it exact. Scott had some made by a machine shop, dont know if he's got more or not.
    Jan 2008
    New Jersey
    2,928
    Gadget- i just wanted to confirm. is the piece you're measuring the one i have in my hand in this picture? As there is an inner sleeve the bolt sits in as well.Click image for larger version.
ID:	54851Click image for larger version.
    Member tikitiki65's Avatar
    May 2011
    Mountain View, CA
    122
    There's a guy on another forum that used this place for washers:
    http://www.phoenixspecialty.com/products/washers
    Here's link to the original thread:
    https://www.crownvic.net/ubbthreads/...Number=3611954
    88 Country Squire
    86 Colony Park, non-op'd
    89 Mark VII LSC, non-op'd
    Didn't JeffBoudah offer these for sale recently?
    http://www.grandmarq.net/vb/showthre...ushing-spacers
    Jan 2008
    New Jersey
    2,928
    OO thanks guys. bgreywolf- I'm glad you posted that! I sent him a message, hopefully he still has a set to sell.
    39,554
    ID number is the size of that step on the poly piece
    OD number is the size of the hole in the frame
    or you ask Jeff to make you some since he's made some for hisself and probably knows those numbers already.
Tags for this Thread
