today is heater core flush day for me when I get home. hoping seriously that I don't have to swap it out. That Lincoln is a nightmare behind the dash.
The MegaMerc
Originally posted by Midnight Drifter View PostDid I luck out? ALLDATA shows 4.5 hours of work for my Merc's heater core, and the instructions don't seem TOO overwhelming...
I started it around 9:30, took my time, got distracted, took food breaks & stuff, still got it done before dinner. There are only 4 bolts left over! The hose from the core to the pipe @ the rear of the manifold was wrong. The one on it still has the tags, it is a Motorcraft dated 2002 which makes sense since I remembered it to be around 10 yrs ago that I built the thing.<br>br>As far as the restrictor, it doesn't have one. When the heater hose blew on my Mustang (car was only around a year old) general consensus was that the restrictor caused higher pressure that toasted the hose. I do beat on it from time to time, are they really useful?
no flow would probably pop hoses all the time though. and yes, the restrictor is a good thing. would you rather replace a hose or a heater core?
Originally posted by slymer View Postno flow would probably pop hoses all the time though. and yes, the restrictor is a good thing. would you rather replace a hose or a heater core?
I purchased mine from late model Jim.~David~
Replaced the broken odo/trip odo gears a week or so ago. Pn is Dorman 924-388...
New exhaust is not as loud as I wanted it to be....
Swapped all 4 snows on today....
The tow truck can't bring the MegaMerc home till tomorrow.....
Left work, leaned into it pretty good on the straight section of the main artery (3 lanes each dir), no burnout, no hard launch.... Lost all forward drive when the loud rattling/buzzing started.... Neutral, no noise, D or OD, noise... Coasted to the next turn off & down the street, pulled to the side & experimented, no noise in P or N, (that just doesn't look right...) Noise in gear... Tranny? looks ok, rear? Why is there black liquid emanating from the pumpkin cover?..... Turns out that one of the Mitymerc's old sponsors sold his flatbed no tow... Arranged for a tow, fell through, So, I am waiting for Pantera to come get it with his cool new truck j/k. I have arranged for it to be dragged home in the morn. I spent the afternoon chopping ice & shoveling to clear the pad behind the garage so I have a place to work. I hope it is just spider gears or something simple.
After the the epic burnout @ Scottfest it made a clunking noise a few times heading back to the ranch, but stopped after that. Maybe stripped the teeth from the clutches? I really don't want to buy gears & set them up while lying on wet frozen concrete... And now it is snowing...
