well today i picked up a signature series town car 1989. car needs work but runs good and is rot free not a single rot hole on the frame. has 114,000 and is titanium clearcoat metallic paint. got it for $600 so i cant complain the car is loaded with every option available for 1989 except for a sunroof and a trailer tow package. has a 3.27 rear have to find out if it's track lok after i fixed the kinked brake line.
so heres the bad stuff with the car that i will have to fix eventually.
Windshield is cracked and will be replaced.
drivers door panel is ripped like usual.
the driver side window goes down a certain way and starts making a grinding noise and doesnt finish going down unless i ease it down. does the same going up. 86VickyLX said its the bushings in the motor.
clearcoat and paint is shot for most of the part(on the roof and trunk and the upper part of the sides) so the car is gonna get repainted looks like crap right now.
trim piece inside the car that goes around the opera windows is not staying on.
driver side leather seat has 2 rips in it and the owner put duct tape over it so i have to find a mint driver side seat.
dashpad is cracked.
vinyl top is faded but only has one small crack in it and it's not very big.
passenger brake line is kinked and needs to be fixed asap.
the ignition switch sticks sometimes in the cranking position so it needs to be replaced.
exhuast has a leak so that will be also be replaced.
thats all i can think of.
the good stuff
has a rot free frame not a single hole of rot i found. has 2 rusty spots on the frame so the frame will be getting por 15'd so it does not rot.
motor runs great and has 114,000 on it and no oil leaks except for one around the drain plug so i think i need to replace the drain plug.
so this will get the treatment it deserves. enough of my ranting here's pics
i really love this car and hope to restore it to showroom condition.
Car came from Binghamton NY.
originally was from Missouri.
Tommorow i am cleaning the car inside and out.
dashpad is cracked.
the good stuff
