Originally posted by hypostang
View Post
My $600 1989 Lincoln Town Car Signature Series(Beverely)
1982 Lincoln Continental Mark VI Bill Blass Designer Series 2-Door(Larisa)-Mods: HO Roller 302, GT40P Heads, Explorer Intakes, HO ECM(D9S), Autodimming w/compass and outside temp rearview mirror, Daniel Stern Lighting Mod, Dual Exhaust, 90's GM C/K Series Retractable Hood Light, Red Digital Dash Display, 92-94 White Leather Town Car Signature Cupholder Armrests, HPP Wheels, Police PS Cooler, Police Trans Cooler. More to come!!!!
The sensor on the mirror is very sensitive , try putting your hand over the front of it and putting the high beams on and see what happens and let me know , I just went through a problem with mine a few weeks ago .sigpic
1988 Signature Series Town Car
Originally posted by hypostang View PostThe sensor on the mirror is very sensitive , try putting your hand over the front of it and putting the high beams on and see what happens and let me know , I just went through a problem with mine a few weeks ago .
$125 for the one that goes in my Mark 6. That's the lowest price I could find. Most want around 200-250. If he's got autodim, then there should be like 3 knobs behind the headlight switch... the main knob and then two small levers poking out... set them both up top together to turn autolamp and autodim off. autodim is on the right... autolamp (turns the headlights on when it gets dark) is on the left. from your pics... it looks like autodim is pretty far down the way. put it up near min and the highs should stay on.
Originally posted by slymer View PostIf he's got autodim, then there should be like 3 knobs behind the headlight switch... the main knob and then two small levers poking out... set them both up top together to turn autolamp and autodim off. autodim is on the right... autolamp (turns the headlights on when it gets dark) is on the left. from your pics... it looks like autodim is pretty far down the way. put it up near min and the highs should stay on.
My problem was the sensor on the mirror , thankfully I had a half dozen of them lying around , It took me three tries t find one that worked .sigpic
Yeah the lever on the right of the switch should be all the way 'up'. I dislike it strongly, you'll bumb it with your hand and poof! No brights when you click. I'd happily disconnect it if I knew how.
Cool beans on the car! If you can't find a good seat I'd check with a shop. If it's only the one panel it may not be a lot to repair.
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
well my axle code revealed i have a 3.27 Locker nice. did a koer test and got some codes and need to know what will cure the codes. car was warmed up to operating temp.
im getting
21- Cooling Temperature Sensor out of specified range or ECT out of range.
34- Defective EGR pressure transducer sensor
44- Thermacator air system fault
94- Converter Clutch Control Circuit Failure
what needs to be replaced to get rid of these codes.
Originally posted by 1987cp View PostWait, so the autolamp feature has a thingy that makes the high beams not come on?2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
Originally posted by tjc78 View PostSome TCs were equipped with not only Autolamp but "Autodim" It allows you to put your high beams on and they turn off when an oncoming car approaches (and then turn back on once it passes). There is a distance control on the headlight switch, and a sensor mounted on the rear-view mirror. My 79 Continental had it and I know it was available until at least 1993 as my Grandfather's 93 TC Cartier had it.
the autodim sensor for mine is behind the grill. Mirror is a normal POS mirror
