my wagon was sorta the same way. i got it shipped here from alberta. the underside is mint, including the frame. only had a slight rust issue behind the rear tires on the outside quarters(got that fixed 2 years ago). you guys dont use salt right?
Long time lurker, first time poster. Here's my story...
Originally posted by marquisman View Postmy wagon was sorta the same way. i got it shipped here from alberta. the underside is mint, including the frame. only had a slight rust issue behind the rear tires on the outside quarters(got that fixed 2 years ago). you guys dont use salt right?
I priced out panels from ford... yeesh. I could build a garage to do it myself in for cheaper than buying new ones. Need to find a guy who works for beer.
if you can find them, they are good lol. one thing to do though(when it gets warmer) is to remove the carpet and make sure you dont have rust on the floor. other than that, looks like you just need a door and front fenders. and of course, remove the vinyl top. also, i wish more places used just gravel, than that nasty salt. they are now using more of that liquid death(brine) here.
Replace the vinyl top if needed. Only the cheapass models didn't come with vinyl tops. Don't wanna look like you have a poverty car do you?
-- the only guy on here who actually likes vinyl.86 Lincoln Town Car (Galactica).
I like it... I just don't like replacing it or sitting on it.
Originally posted by slymer View PostI like it... I just don't like replacing it or sitting on it.
theres a big unfinished seam between the small window and the rear glass that has to be filled in. Theres also a line of holes across the roof for the belt. If yours has the coach roof with the fiberglass shell on the back, then that also has to be dealt with. if you have no metal trim around the rear glass, and the vinyl tucks in, its got the shell.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Posttheres a big unfinished seam between the small window and the rear glass that has to be filled in. Theres also a line of holes across the roof for the belt. If yours has the coach roof with the fiberglass shell on the back, then that also has to be dealt with. if you have no metal trim around the rear glass, and the vinyl tucks in, its got the shell.
Anyone know a guy who can redo a vinyl roof in central Alberta? For a fair exchange? I hear them that Americans can git'erdun for only $100-200, is this true? Only thing I can find here is $500, which is more than I paid for the car, and a complete vanity purchase, with no functional use. So it's hard to justify.
But I want a new one oh so bad.
500 is more realistic.
If it helps, it's not a totaly vanity purchase as a severely damage vinyl top will eventually rust undernearth.
It's a LONGGG job, but it can be done at home.
there's a thread around here somewhere about it.
It is a ROYAL PAIN though. LOTS of labor.
Basically you buy a sheet of vinyl big enough, and usually a special underpadding of foam, and rip the old stuff off and put the new stuff on.
The problem is that the old stuff is REALLY REALLY glue on, and basically needs to be scraped off. like Slymer says there's a thread around here somewhere.
Oh and you'll have to remove the trim, which involves taking the headliner out, and the b-pillar interior panels out, basically taking everything above seat level other than the dash out of the car for access to the back of all the moldings/trim.
It's not particularly skilled work, the main skill is in getting the vinyl to sit right with no wrinkles, but that's mostly taking your time. It's just epically time consuming and physically difficult. Picture that gunk left on books and stuff when you take off the stick wrong, but tougher, a quarter inch thick and covering every square inch of the vinyl area, and you have to get it all off completely and not put huge dents in the roof AND seal it so it won't leak again.
Originally posted by johnunit View PostBasically you buy a sheet of vinyl big enough, and usually a special underpadding of foam, and rip the old stuff off and put the new stuff on.
Now, all the crap work aside... Does it have to be vinyl only for longevity? Not that I'm going to go out and do this (based on the glue reference. I deal with shit quite similar to what was described). But, what would be the disadvantage of oilskin, other than the increased maintenance of greasing and dying? I only ask out of curiosity, and the fact that I like the looks of oilskin over vinyl.
I think longevity would be a big thing. Keep in mind that any shrinking or stretching becomes a problem quickly when stapled/glued to a rigid structure and exposed to direct sunlight, rain, snow, etc. There were "cloth" tops offered, but how close they could look to oil skin and what the actual product name for said cloth is, I don't know.
