Results 1 to 6 of 6
Thread: Aero 302 swap.
    Jul 2010
    PDX
    206
    Default Aero 302 swap.
    Is a 302 fairly straight forward swap in a early 92 aero? Will a underhood harness from 90 TC fit right in?
    NY
    13,284
    Search around for threads by username: Lincolnmania.
    He has completed the swap into a 93 Grand Marquis and his threads may hold answers for you. Another active member also has completed a similar swap and will surely chime in.
    The bigger the Blob the better the job!
    Quote Originally Posted by Grand Marquis GT View Post
    You have to be the worst poster and/or the biggest fucking idiot on this planet.
    That's like swapping herpes for crabs.
    My 1987 Crown Victoria Coupe: The Brown Blob 0-60 in 8.43 sec, 1/4 in 16.75 sec @ 84mph
    My 1994 Escort: The Trusty Escort
    central VA
    11,985
    Its not really a matter of the harness "fitting"... no it does not hook right up to existing harnesses in the aero, but its only a handful of wires that need to be franken-spliced to make it run, and a few more to get everything else working.
    As long as you have a 'bastard-block' car, a 5.0 will bolt up to the AODE.
    I think the thread you need to look for is in the "Scotts automotive" forum section
    The sly one slymer's Avatar
    8,429
    his was a 92 grand marquis with the bastard block (4.6 with the mechanical AOD that still used the small block bolt pattern that the older 302 uses)
    302 is a direct bolt in, but the wiring I think needs to come from a box panther or you get to run quite a bit of spaghetti and wrap it up afterwards. also depends on what engine computer you're planning to use as to whether you'll be adding wires to a specific harness or not.
    Lincolnmania's 92 GM hauls ass too.
    edit: here's the thread for the lazy: http://www.grandmarq.net/vb/showthre...-yea-were-nuts!
    rides: 88 MGM, 93 Vic, 82 Mark VI,
    central VA
    11,985
    aahhh I did not know the bastard block cars used the old AOD. That makes more sense
    Jan 2007
    Westmont, New Jersey
    9,188
    Yeah. Technically you need a different driveshaft, something about the trans mount putting the transmission further forward than a 302 powered car. The driveshaft in Scott's 92 is a tad bit long. An AODE aero driveshaft would be desired there. Or a 4r70 aero or whale driveshaft with a different slip yoke.
    Vicky
    Currently Undergoing A Skippyville Beauty Makeover! Too Much Stuff To List
    Blue
    Mods So Far:
    5.0 HO Swap from 92 Cougar (Courtesy of Lincolnmania, Gadget73 and SVT98t), Electric Cooling Fan, Autodimming Mirror With Compass, Frankensteined but fully functional JBL Premium Sound System, HPP wheels, Working A/C, more mods to come soon!
