Probably been covered, at least in part before. Have a 1995 Merc GM, that is stock. New Motorcraft plugs, wires, TPS, EGR cleaned (along with ports), DP sensor, 5W30 Mobil1. Been getting (according to the Digital Dash) around 14-15 City Mileage (mixed but mostly with A/C on). Is this "normal" or "low"? Brakes are not dragging and wheel alignment is good along with factory tire pressure. Thoughts?????
Gas Mileage Question
"Cars are for driving - PERIOD! I DON'T TEXT, TWEET OR TWERK!!!!"Tags: None
define "city"? That doesn't seem out of line for an aero though, no.
Stop and go traffic - lights, etc.....NO highway. 0-50 or so usually.
Normal.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
WOW! My other car (1987 Merc GM with the 5.0) does better! Maybe time to sweat and turn off the A/C. Wonder what difference that would do besides make me uncomfortable?
I'd venture to guess at least a mpg (which is about 7%)
You may also have less advantageous gearing (3.55 seem to be the best in city). It's also very possible for an aero to be significantly heavier than a box with a 5.0, depending on options.
Curious about the weight issue. VERY good point! Got to look that up!!
dead of summer, the 93 would get 19mpg with all city with AC blasting. Check tire pressure.
Tire pressure is as stated on Door Jam label. Have tried higher pressure (35 psi) but didn't seem to change the numbers. Bobby
got me then. I would suspect a sticky caliper (won't generally feel it if it's a rear one) that's possibly dragging a bit... or the e-brake cable is stuck on one or both.
I guess the drag would have to be barely minimal as the car REALLY moves. Maybe the mileage is as good as it is going to get???
maybe. If it's got the towing gears (or better) then that's probably about right. My 93 has the base setup with 2.73 gears in it. It will have 3.55 TL in it when scott's done with it though.
Not sure what the gear ratios are. Didn't have it new. How can I tell??
TR = U65XX and AX = 5. Does that help??
