Hey everyone just a small question I herd that Ford has a new 302 in the 2012 Mustang. Any idea on just how much work it would be to swap one in with a stock AOD. Thanks
New 302 In A Old Ford
there are adapter plates out there to mount SBF stuff to mod stuff. The new 302 with ECM/Harness is about $9K. It puts out over 400hp. The stock AOD WILL die. You can however have an AOD rebuilt with HD parts to be able to handle it with little/no issue. The problem comes with having to sort the TV cable BS.
Originally posted by slymer View Postthere are adapter plates out there to mount SBF stuff to mod stuff. The new 302 with ECM/Harness is about $9K. It puts out over 400hp. The stock AOD WILL die. You can however have an AOD rebuilt with HD parts to be able to handle it with little/no issue. The problem comes with having to sort the TV cable BS.
I can just see a rig setup with the TV cable driven off the skinny peddal.
If you have the 15 to 20k to do it it would be really cool.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
ive had the pleasure of looking at one up close and personal, the cyote will fit, it basically the same way you would to drop a 4.6 in a box. however you will need to cut the crossmember up and make a tubular mount for it though. im sure it can be done, and i know a guy who specializes in such things, but the only reason for putting one in a box is for shock value and say , yeah i did that, you can get a cammer motor,which is basically the same thing. also you would need a c4 bell housing adaptor, and the flywheel to go with. i have both of those items at the shop hehe. but for the money i can build a pushrod or a mod motor and make more hp and tq than that cyote motor anyway so 15 k.. honestly would be best spent in just building something far nastyier than one of those things.... slymer what are HD parts for an AOD, no such thing, there is however some parts you can use to beef one up, but then again thats why ill be going to an aode....89 townie, mild exhuast up grades, soon to have loud ass stereo....
It would be interesting to see how quick a stock AOD would explode behind one of those things. I'm betting it would die before your first oil change.86 Lincoln Town Car (Galactica).
I would just keep an eye on CL if you really want to put a Mustang motor in, I saw a complete 2001 or later 4.6 Mustang motor with 5spd for $800 around the Pittsburgh area (sold after a couple weeks up). I've got some old Muscle Mustangs & Fast Fords magazines from back in the day in a box around here which detail different builds with costs and you can hit 4-5-600 hp easy on a 302 if you want, you just have to build it properly.
