I got mine to sit high enough up, about where the stock stuff is.
do Mustang headers fit?
Originally posted by johnunit View PostThe issue is almost completely the downpipes before the cats on the mustang stuff. That's the only part that is screwed up. If you have some welding ability it's an easy fix, but if you can weld then buying 2 cats and a universal piping kit might be cheaper...
Ok another unrelated question, I asked before but can't find the thread I asked it in, brain fart. Do 302 headers fit on a 351? I thought about a 351 swap and it looks like only BBK has 351 swap Mustang headers, haven't found any others.88 Town Car (wrecked, for sale)
The 351 headers go down and farther from the heads to accomodate for the 351 being taller and wider. you MIGHT be able to run custom downpipes from a 302 header on a 351W but they will NOT bolt up to a stock-location mustang exhaust system.
FWIW I and at least 2 others run 351 BBK swap headers and (aside from some quality control issues Brown Muscle had) they fit and work well.
The other reason to use 351 swap headers is to gain extra clearance near the evaporator case. I have a suspicion that with 302 headers, it would put the collector awfully close to that plastic box, possibly close enough to melt it.86 Lincoln Town Car (Galactica).
yeah now that I think of it, I doubt it'd work. I have less than an inch clearance as it is.
351 swap headers are designed to mate up to the stock exhaust location; I used em on my TC. You can use 302 headers on a 351 but they wont mate up to your pipes without mods on one or the other
'80 Town Coupé
For Pantera77
Originally posted by pantera77 View Post90 Town Car manifolds, AKA Lincoln Logs, are tubular manifolds. They probably flow a bit better than the stock cast iron logs, and are significantly lighter. They bolt up 100% to the factory downpipes, and also somewhat clear the plugs on gt40p heads. They are the best bet if you want to use your factory exhaust, but I doubt they flow even as good as even factory stang headers.
I've never seen those headers with O2 bungs... Probably a set of mustang headers with a bung welded on. I'd just get aftermarket headers, some longer O2 sensors, a mustang H-pipe and custom midpipes for the bird.Builder/Owner of Badass Panther Wagons
Originally posted by mrltd View PostI've never seen those headers with O2 bungs... Probably a set of mustang headers with a bung welded on. I'd just get aftermarket headers, some longer O2 sensors, a mustang H-pipe and custom midpipes for the bird.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
