CA smog >=(
    CA smog >=(
    Yo fellas is great to be back on the forum.
    i passed all the emmissions, gas cap, and gas tank test.
    which was great
    but the guy couldnt find the timing marks on the balancer.... he wouldnt charge me for the test.
    i went to to the store and put white marks on the 0,10,20,30 on the balancer.
    i went back to the smog guy and he found that the car was timed at 25 degrees at idle. he also could not find a *sprout* to remove a *black wire* from which he said he had to remove inorder to time the car properly.
    long story short. he couldn't pass me b/c he couldnt time the car.....
    this is the first time this has happened, maybe other smog guys didnt give a damn about the timing
    question: where is the sprout and so called black wire to remove inorder to time the car?!
    67 Ltd tudor
    67 Ltd 4door
    85 Ltd 4door
    welcome back. you still have the cfi right. if you time the car with spout still on the timing will be high. the spout is on the same wire loom for the tfi on the distributor. it has a plastick piece that you pull out of it to close the circuit or what ever. you still have the edelbrock manifold?
    1984 mercury grand marquis ls rebuilt 306 flat top pistons with factory cfi and lincoln headers with single glasspack dual snorkle air cleaner. Gloss black paint with slick top coversion.
    1986 mercury grand marquis colony park 5.0 sefi dual exhuast thrush turbos with h pipe and turbines
      yea i still got the cfi, hoping to upgrade to sefi or throw in a full efi roller engine with all the smog crap..... i still have the edelbrock manifold.
      so your saying if i remove that connector that is attached to the distributor it will reduce the timing?!
      67 Ltd tudor
      67 Ltd 4door
      85 Ltd 4door
        you dont remove the harness from the tfi the spout connect lays on top the same wire loom. looks like this
          how did the edelbrock do on the cfi. any changes. sorry to ask but i think your the only one on here thats done that to a cfi and am courious as i my self has cfi
            it did pretty good when you floor it or are aiming to pick up and go or to get on the free ways here in california.
            it would definately benefit with better heads, cam, and a mega squirt system to adjust the a/f ratios
            on my lopo 5.0 im not complaining.
            67 Ltd tudor
            67 Ltd 4door
            85 Ltd 4door
              Your smog guy is really going by the book... what a pain in the ass. I never have had a smog tech check my timing. I wouldn't want them monkeying with it anyways. If it passes and looks stock let it go... come on.
              The timing will read about 10 degrees higher with the spout connector plugged in.
                spout on a 85 is a round one wire plug near the distributor mang
                  Can we see some pictures of that Edelbrock intake, cfi setup please.
                    here's a link on how to set the timing
                    88 Country Squire
                    86 Colony Park, non-op'd
                    89 Mark VII LSC, non-op'd
                      and here's one with panther-specific pictures, including a pic of the CFI SPOUT connector
                      This is a must-see site for fans of American luxury hot rods. Message forums, tech advice, news, and automotive performance links are offered for Lincoln Mark VIII and Mark VII, Lincoln LS, Town Car, Continental, Navigator, Aviator, Zephyr, MKR, MKS, MKZ and more.
                        I passed. car did very well, now i gota find out why i only get 15mpg.... i think im going to bump up the timing. already replaced the rotor,cap, plugs,wires, fuel filter.
                        67 Ltd tudor
                        67 Ltd 4door
                        85 Ltd 4door
                          my 88 only gets 14 around town on a good day. typical is 13. I know I'm probably getting a little blow-by on combustion due to the tired engine. only about 105psi per cyl. they're all that way though... so it's still balanced well.
