Results 1 to 17 of 17
Thread: Is a 4 wheel alignment necessary?
    Member V8GrandMarquis's Avatar
    May 2009
    Montreal, Canada
    248
    Default Is a 4 wheel alignment necessary?
    Hey guys I was just going to get a alignment but do I really need a 4 wheels alignment. I don't think there is much to go wrong in the rear end but what do you guys recommend. Thanks.
    Jan 2008
    New Jersey
    2,664
    You have a solid rear axle...For all intensive purposes it is not adjustable. the front will simply be aligned in relation with the rear. most shops will advertise alignments as 4 wheel alignments, even if they only touch the front.
    Also make sure you find a trustworthy shop...they are hard to come by. a lot of places will do half ass alignments, and even less will dare touch the camber/caster adjustment. If you can ask for the before and after print out sheet.
    +'82 Ford LTD-S Police Car. 351w, 2bbl 2150 Carb, Full exhaust headers to tails. 3.27 Trac-Lok Rear. Aluminum Police Driveshaft. 86 Valve Body Baumann Shift kit.
    +1989 Mercury Colony Park "Large Marge" Lopo 302. 3.55L K-Code Tow package, Baumann Shift Kit, Big brake swap, rear discs, HO intake/TB, custom exhaust.
    May 2009
    Montreal, Canada
    248
    Great thanks for the extra info.
    Jun 2009
    Nova Scotia, Canada
    8,260
    always ask for the print out when you get an alignment...if they say no go elsewhere
    Oct 2008
    Buffalo, NY
    4,936
    Also that insert cheap price is just for a toe and go. Expect to pay extra for camber/caster.
    GMN = life johnunit's Avatar
    Apr 2009
    Toronto
    5,084
    Some great advice here. +1 to everything as someone who's done alignments at a couple different shops.
    I just had my race car aligned at NTB. The rack they use is a very impressive setup. No way to screw that alignment up. And, at NTB you can stand right there with the dude as he is making adjustments.
    2009 GM, 45,000 miles
    ADDCO Sway Bars, METCO Control arms & Watts link, KYB CVPI shocks, 3.27 Track Lock, GT500 wheels, Eagle F1 Supercar tires, Walker dual exhaust, AFE Cold Air intake, ADTR ported upper manifold, Stillen Sport Rotors, Hawk HPS pads, Hypertech Programmer, 93 tune.
    Jan 2007
    Westmont, New Jersey
    10,110
    The idea of a 4 wheel alignment in our cars case is to align the front wheels to the rear. Basically, if you just have a 2 wheel alignment, the front is all good, but the rear may have some damage, bent control arms, etc. Camber and Caster in a box panther sucks balls. 92+ for the win.
    Vicky
    Blue
    Mods So Far:
    5.0 HO Swap from 92 Cougar, GT40 Intakes With Remanufactured GT40P Heads, Contour Cooling Fans, Autodimming Mirror With Compass, Frankensteined but fully functional JBL Premium Sound System, Working A/C, Big Front Brake Swap, more mods to come soon!
    35,324
    I had to have mine done 4 times before someone adjusted it right. The first time the toe was done. I went back and asked why the caster and camber numbers were way out of spec, and was told "its not adjustable". I have big brakes on my car, and it has 2 sets of adjustments so thats BS. The second place didn't tighten one of the control arms and it shifted on me some 800 miles from home. I tightened it as best I could with the tools I had, and took it back when I got home. Don't know what they did, but it pulled. I went somewhere else, and they made it drive right. I don't have a printout, but the car goes down the road perfectly straight with no quirky handling habits and it doesn't chew the tires so as far as I'm concerned, its good.
    2,041
    " all intensive purposes" It's for all intents and purposes [i get it mixed up all the time] The other one I used to have trouble with was "6 in one hand half a dozen in the other"
    But actually... IS there a way to correct anything in the rear?
    My right rear toe is at .14 and my left rear is at -.07; is that far enough out of spec to say that something's the least bit bent?
    And yeah, for $80, the technician gets paid $15... when I do alignments, sometimes, they are half-assed. I can't spend 2 hours on it and make a fair wage. And if something's more than a little frozen, where a propane torch won't get it (or there's a rubber bushing on the other side of that eccentric cam), I don't mess with it. We've had more headaches than appreciative customers, trying to deal with rusted hardware. Or if it's a truck that got lifted, and I have to mess with the torsion bars to correct things, or tear components apart to install aftermarket adjustments and shims, etc., it's easier just to say "it's not adjustable..." and move on to the next job, than price it all out only to have it turned down anyway as too expensive.
    2,041
    hey by the way, I was looking at my '90 box setup... the upper control arm has those two slots, right? I corrected caster by twisting it (moving just one slot outwards), and that sortof makes sense: it effectively shifts the upper ball joint backwards, which directly impacts caster. But it also screws up camber. It looks like the slots only move in and out, not side to side? So I can only get camber or caster correct, but can't fix caster without screwing up camber...? Or am I missing something?
    I'll be taking the upper control arm off entirely, tomorrow; which may show me more.
    Now a Chrysler owner. mercurygm88's Avatar
    Jul 2011
    The Firelands
    1,119
    I had mine done at pep boys last summer cost me $60 they did camber,caster,and toe, and gave me a printout. That was over 15,000 miles ago and all is still good.
    2013 Chrysler 200 Touring - Purchased 5/2/16 at 27,729
    2001 Lincoln Town Car Executive Series - Purchased 04/18/15 at 108,653, traded in 5/2/16 at 139,000
    1988 Mercury Grand Marquis LS - Purchased 6/26/11 at 82,610 totalled 4/16/15 at 137,000, Not my fault.
    1995 Cadillac Eldorado Sport Coupe - Purchased 6/2010 at 110,000 spun a main bearing 5/2011 at 135,000
    1995 Mercury Grand Marquis GS - Inherited 10/2009 at 105,000 totalled 4/30/10 at 120K, My dumbass fault.
    1990 Toyota Camry DX - Inherited 7/2008 at 78,000 sold 10/2009 at 90,000
    35,324
    Quote Originally Posted by BerniniCaCO3 View Post
    you're not missing anything, and pulling those arms won't show you anything you haven't worked out already. Basically you play with it to get the best balance and call it good. The lack of adjustability is probably the single biggest reason why they went to cam adjusters starting in 1992.
    Jan 2007
    10,110
    Had my car aligned at work. Our rack is shit though. Car went straight down the road, but no matter what we tried we couldn't get the steering wheel straight. About an hour at Scott's with Ivan's eyeballing and slight tweakage of tie rod ends made it perfect!
    Vicky
    Blue
    Mods So Far:
    2,041
    Just did my front suspension: I like to indulge, and had it all apart, so in addition to new polyurethane bushings, did ball joints (uppers probably were still just fine: lowers had no play yet but where gravelly when turned), and sway bar endlinks and frame mounts (endlinks were ready to rust through!), and new springs just because.
    Bought the "lifetime alignments" at firestone; the guy got it to:
    camber -.10 -.15
    caster 3.25 3.45
    toe .03 .05
    can't really complain!
    Maybe new bushings helped align things better?
    Or just having them apart and wire brushed, make the top arms easier to adjust to where they needed to be without binding.
    Or that the guy who did the alignment was 50+ years old and knew what he was doing better than I do yet
    Happily the upper control arms were really pretty rust-free, protected up top, perhaps.
    rear toe eccentric cams are the bane of my workday, they always rust fast.
    Jan 2007
    10,110
    You put the slides back in the right places right? The rears have smaller slides than the front adjustments...
    Vicky
    Blue
    Mods So Far:
    2,041
    wait, they do?
    shit, I don't think so. They fell down and out, I just put them back.
    Do I need to care if it's all in spec now?
    This is a 1990; by slides I assume you mean the rusty squares with the nylon-rimmed locknut in the middle?
