There's a Vic in the pick-n-pull with a k code rear end. I just want to know if it's worth taking the whole thing or not. I would imagine it has the 11" drums since that should be a tow package car (hard to tell, not sure what tells for sure since the car's been gone through) but I can do without the bigger brakes if that's the only advantage.
I'd much rather take the ring and pinion and the limited slip carrier out of the rear and swap it into mine, be a lot less work and cheaper. I can get a shop manual to figure out how to get it out but i'm not even gonna try to do the install, differentials are so out of my league it's not even the same sport.
And I checked Summit for spacers to help even out the narrow rear, would these fit over the wheel hubs? Looks like kind of a universal spacer from the pic but it says works with 5x4.5 so i'd assume if it fits over the hubs they'll work. Also it says sold as kit, that means individually right, i'd need to order two? Link: http://www.summitracing.com/parts/AAF-ALL44123/
