Is there anything that you can upgrade to get more power out of a bastard block 4.6? Or is it a good idea to upgrade to a 302? I'm planing this as a 3 to 5 year project.
1992 Mercury Grand Marquis with bastard block.
1992 Mercury Grand Marquis.
Upgrades: Big Brake Upgrade, digital dash, Custom ignition Switch system, sequential tail lights, Teflon Fuel lines, LED interior lights, rear end rebuild with limited slip.
Future upgrades: 5.0 swap, 4r70w swap, aluminum driveshaft.
sigpicTags: None
Originally posted by pivichot View PostIs there anything that you can upgrade to get more power out of a bastard block 4.6? Or is it a good idea to upgrade to a 302? I'm planing this as a 3 to 5 year project.
The other option is to rebuild the Bastard short block, throw PI heads and intake on it, and modify the throttle body for the cruise and transmission TV cable.
Responses are going to be split down the middle most places, here they will be slanted towards the pushrod 5 liter. I can't say which motor is better but I'm more familiar with the 5.0...I think it's the case with most people here as well, but they'll tell you the 302 is better anyway.sigpic
swap in a 351w (it'll bolt up) and go to town with upgrades on that.
preferably a roller (94/95) 351 too.
there are a few other things to swap with a 302, namely the motor mounts and the trans crossmember, but its not that horrific. I dont think you can do much to the bastard block motor, and changing it to one you can do something with involves a trans swap and a shitload of wiring. The 302 EFI harness is child's play compared to the modular harness. If you were doing a 351 swap, likely the 302 harness is still going to be your starting point since the 302 and 351 are pretty much the same as far as where things sit on the engine.86 Lincoln Town Car (Galactica).
I was mostly towards the 302 swap since I saw Scotts 302 powered 92 Grand Marquis. Which Ecu from which car should I use? My idea is to buy an engine from a junkyard, I will check it before to make sure nothing is cracked. I basically want to build the engine from the bottom up. Aren't the engines from the 85 and up grand marquis roller engines? Also I would need to build a strong AOD. Now about gears in the differential. I want this car to be my daily driver. I don't do highway miles. Which type of gears are better for city driving and still feel the performance. The thing that I am not sure yet is about which headers will fit for the engine on the car and also the AC on how to make it work with the 302.1992 Mercury Grand Marquis.
86 and up for sure. i don't know that all 85s were.sigpic
4.6 performance parts are expensive!
my engine just happened to be out of a 92 cougar.
3.73 gears are on my list of things to do to the 92
one question. how much mpg does you car do Scott? Right now with the bastard block I am getting between 10-12 in city.1992 Mercury Grand Marquis.
Originally posted by pivichot View PostRight now with the bastard block I am getting between 10-12 in city.'79 Continental Town Car
'90 Crown Victoria LTD
'94 Crown Victoria
sounds like it's got some issues with mileage like that. even with a heavy foot my 302 with original o2 sensors isn't that hard on fuel around town.sigpic
it does like 16-20 mpg.......sorry i dont drive in the city but i do in mountains, it will do 20 easy on the highway
