Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: R134 fittings question
    2,041
    Default R134 fittings question
    Hi!
    Got a question for you guys.
    I had my a/c converted to r134 a couple years ago, before I knew about cars.
    They replaced the required components (condenser, evaporator, and accumulator...?), so I'm told,
    but left the R12 fittings on it.
    I know there are adaptors, probably they used them.
    It's time for a recharge-- cold but not icy cold.
    I bought R134 fittings at the local parts store.
    Looks like they're threaded.
    SO, if I unthread the R12 fittings, will my system just vent everything to atmosphere?
    Or are those fittings schrader valve protected, I can unscrew them, screw in the r134 fittings, and proceed with the recovery/charge machine as per normal?
    Let me know before I break those fittings free! I won't know if there's a schrader valve underneath until it's too late!
    Thanks,
    -Bernard
    Proud Owner Of A 1987 Mercury Grand Marquis! miamibob's Avatar
    Apr 2011
    South East Florida
    4,478
    Shouldn't be an issue. The fittings are like tire valve caps. Remove and replace with the new fittings. Since the fittings are different sizes (by design) how did they put the R134a in and service the system with the old fittings? Something here isn't right!
    Jan 2007
    Westmont, New Jersey
    10,125
    Good R134a fittings require you remove the shraeder valve from the accumulator. The new fitting should have one in it. High side you just thread onto your existing fitting.
    Also, I'm willing to bet they used Freeze 12 or some R12 replacement other than R134a.
    Vicky
    Blue
    Mods So Far:
    5.0 HO Swap from 92 Cougar, GT40 Intakes With Remanufactured GT40P Heads, Contour Cooling Fans, Autodimming Mirror With Compass, Frankensteined but fully functional JBL Premium Sound System, Working A/C, Big Front Brake Swap, more mods to come soon!
    2,041
    Ah! Nevermind-- there is an R134 fitting on the low side. The high side is just threaded like a tire valve stem. My kit looks like it can thread on to that, however.
    Sounds like someone did do r134 then.
    How many pounds r12 did these take?
    If I put in r134a, how many pounds of that should i do? (that is to say, with r134a, do I put in more or fewer pounds than was originally called for with r12...)?
    thanks!
    Apr 2011
    South East Florida
    4,478
    Need to know EXACTLY what is currently in the system and what the system should take. R134a is usaully 80% volume of R12.
    19,876
    DO NOT MIX.
    Period.
    They are NOT compatible with each other. If you mix, the system will pretty much dissolve due to the acid that is created.
    Apr 2011
    South East Florida
    4,478
    I assumed the R12 was COMPLETELY removed and the right oil put in with the R134a.
    Jan 2007
    10,125
    Look on the fan shroud it should have a label for that. I looked up the capacity on Mitchell, and according to them our systems take 3.25 pounds of R12. So 80% of that will be what you fill your system to with R134a.
    Vicky
    Blue
    Mods So Far:
    panther lover forever gabegt90's Avatar
    Damascus Maryland
    5,404
    Last time i recharged mine 134a the machine said it was 2 lbs 13 oz with eaister oil
    35,720
    A retrofit is supposed to include a new label stuck under the hood somewhere with exactly how much of what was used.
    Stow It! GM_Guy's Avatar
    Ontario, Canada
    3,006
    And if you got the label, take a photo of it. My label has faded and gotten so stained from oil spraying that I can't read it anymore, other than "ester oil".
    35,720
    yeah they are usually just a paper label, filled out with ball point pen. 2-3 years later and you end up with a colored bit of paper that has no useful writing on it in a lot of cases.
    19,876
    no papers on my vehicles... but they're all converted with proper fittings.
    I post a lot... GoodSamaritan's Avatar
    Lawrenceburg, Ky
    2,233
    Quote Originally Posted by slymer View Post
    DO NOT MIX.
    Period.
    No offense, but I think that much of the info on this blows the problem out of all proportion. I've seen many systems that were mixed and ran just fine... for YEARS. It is illegal, but it seems to work.
    Axle codes
    Open/Lock/Ratio #
    G / H / 2.26
    B / C / 2.47
    8 / M / 2.73
    7 / - / 3.07
    Y / Z / 3.08
    4 / D / 3.42
    F / R / 3.45
    5 / E / 3.27
    6 / W / 3.73
    2 / K / 3.55
    A / - / 3.63
    J / - / 3.85
    2,041
    I bought the fittings kit at the local parts store for $15, comes with a label-- I filled it out myself (but did not add my name/address, as that would make it a legal document claiming that *I* legally did the conversion and was licensed to do so, and I'm not).
    Since it already had the low side R134a fitting, and I was told it was converted when I bought it, I figure it has been.
    I recovered 1.5lbs, added back in 2.6lbs. Didn't actually see a huge difference, just a bit colder, but, it hasn't gotten truly hot here yet-- I may notice once we get 100deg weather in mid summer!
    And am just glad I didn't lock the compressor or anything I saw it happen on a car that came back from the body shop; they'd had to replace the condenser along with everything just behind the bumper, and must have done something wrong in refilling it. The machine makes it idiot-proof, designed for idiots really, but maybe using gauges you can get it wrong and get liquid into the compressor?
    It looks like it might have original hardware, if so, then yes, some R12 and R134a DID get mixed.
    But if the question is whether mixing will destroy your a/c components,
    BUT to do it right you're supposed to replace most of those components anyway (evaporator, condensor, and... is it an accumulator or a receiver/drier that goes with fixed orifice tube),
    if they do corrode out eventually, then as I see it you merely bought time.
    2,041
    hey-- never looked under it, but, is there a hole under the evaporator, and if so, can I fit a hose under it and direct the condensation AWAY from the frame?
    Any modern car does this.
    Well, any modern car has the evaporator in the cabin, and if they didn't direct the condensation away you get soaked carpeting!
    19,876
    Quote Originally Posted by GoodSamaritan View Post
    well, that's what I was told when looking at a system that had rotted out from the inside. They had mixed oils in there (no flush, just swapped fittings and filled with 134a). within 2 years I was told is when the system sprung a leak from the inside of one of the hoses. Maybe it was just moisture rotting out the lines from the inside. But the whole system was scrapped because of it. Every part was well rotted. This was on an old F150 IIRC.
    19,876
    Quote Originally Posted by BerniniCaCO3 View Post
    There should be a drip hole... and yes... many folks have done that over the years.
    2,041
    damn, why didn't ford just add a $2 hose from the get-go!
    I'll do that TODAY!
    19,876
    Heck... why didn't they just put the 302 HO in them... mainly because they didn't want them to outpace the mustangs (panthers handle better with little to no upgrades compared to the fox bodies of the time.
