Lincoln is sitting at work with a blown water pump, I need to limp it back home to fix it. I'm just wondering if swapping it out is a simple job. It looks easy enough, being right on top and easy to get to, certainly a lot easier than changing one on an 02 Taurus which involves removing every other accesory and the wheel well.
Also what else whould I replace while i've got it off? It'll get new belts (might try deleting the smog pump while i'm at it), probably a 190 degree t-stat to run a bit cooler for summer but what else?
