I have cured the lopo miss
    Yeah thats right after nearly nine months of throwing parts at this thing and practically replacing everything other than the engine itself it is cured. I have started 3 threads in the past outlining my issues with a miss between 65-75mph that was incurable. Today I finally got around to replacing the map sensor vacuum line and the one going to the purge solenoid, the only two that I hadn't already replaced, and guess what no more miss. I have driven about 60 miles since then at speeds of 65-75 and have yet to feel it miss. Heres the previous threads I had started for reference
    http://www.grandmarq.net/vb/showthre...iss&highlight=
    http://www.grandmarq.net/vb/showthre...sor&highlight=
    Note: all three of these threads pertain to the issue that I have now solved and thank god it was really starting to drive me crazy.
    CONGRATULATIONS! Nice job keeping at it and fixing the problem! I know your happy to finally have that issue resolved.
      Yes it is a relief now the only issue left to contend with is rust.
        Nice job! By the way, what are the sizes of the lines you mentioned? Inside or outside diameters??? Bobby
          Nice find! I know this wont help now, but may come in handy in future.............
          This is where a smoke machine comes in handy! Could have found that leak in a few minutes. I don't know how many shops in the States have these machines, but its sometimes hard to find one in the UK. I have actually made my own! Although hindsight is a good thing!
          Well done on the cure though.
          Do these management systems display short term and long term fuel trims through live data? Is it too early?
          Andy.
          www.lowcamaro.com
            The line I had was 5/16" I.D. and about a 1/2" O.D.
              Is that the spec for BOTH lines??
                Thats what I used doesn't mean its what the factory used but it works. The best part was it didn't cost me a dime to do it. I went to the local oreilly's and my buddy who works there went in the back and there was 25' of the stuff in the scrap bin and he just gave it to me, he said someone came in and said they needed 25' of 5/16" I.D. hose and he went and cut it and brought it out and they were like oh no thats too small.
                  Thank goodness for folks that can't measure - SCORE!!!
                    Vacuum line gets sold by the inside diameter. Outside diameter is whatever it happens to be.
                    Andy, smoke machines until recently have been the domain of new car dealerships and emmsiions specialty repair shops. Seems they've only been trickling into regular shops over the past few years.
                    Alex.
                      I've said it before, before getting overly crazy replacing parts, do a tuneup and replace all of the vacuum lines. It fixes more problems than you might believe. Probably costs less in vacuum line than it would to pay a shop to hook up their smoke machine to it.
                        I had an oodle of vacuum line left so I went back through and did the line from the smog pump to the cruise servo at least I didn't have to pull the plenum for that one, I've got about 3 feet left stuck away in the trunk for any future project requiring such things.
                          Smoke machines are relatively easy to make if you've got the goods.
                            I thought I recognized the smell of the smoke. It smelled like my toy train's smoke. WOO WOO!
                              mercurygm88,
                              Is your car still doing good since you replaced those 2 vacuum hoses? No problems?
