302 to 4.6
    302 to 4.6
    I got my hands on a 84 GM 2 door. The engine is weak and needs attention. is a swap to a 4.6 a good choice? I will have a chance to get a 98 tc as a parts car for the swap.
    Its a swap thats been talked to death, but only a few have ever completed. The most difficult thing I'd think would be wiring everything up. Provided you have a complete parts car, it'd just be a matter of making it happen. You should have everything you need between the 2 cars. Keep in mind, you'd be using the newer trans too, with its computer control. You couldn't use the AOD if you wanted too since the bellhousing is different. You'll also probably be best to use a driveshaft from a '95+ CVPI, the one in that Town Car is too long, as is the one in the '84 since that Town Car has the long tailshaft on the trans.
    -Steve
      It's a lot of work for, in practice, pretty much no gain. Some more power, but much more expensive to modify on a dollar per hp basis.. More reliable in theory but that's probably not true for a used engine swapped into a car it wasn't built for vs. rebuilding the original engine. Maybe better fuel economy but not by much.
      What sort of attention does the engine need? burning oil? bad compression or leakdown test results? knocking? Or just using more gas, hard starting, down on power, etc.?
      Perhaps more importantly, what is your budget and skill level?
        i did the opposite, i have a 302 in my 92 grand marquis, i had two broken bastard block 4.6's (the good used engine broke a spark plug in the head and at that point is was cheaper to install a 302 than pull the head and send it out and change the timing chains).......find a 88-92 mark VII parts car instead and swap the 302 ho in
          it will only lead to tears......
            Thanks for the input. it was just a thought since i would be able to get the tc for $600, no it not worth fixing up and driving. I was going to use the trans as well, my main concern was the motor mounts, if they were the same I can do this if I have to fab new mounts well It's beyond ability. Guess it's going to be a 351 SPFI
              From the TC you can use the front upper control arm, spindels and brakes. The rear brakes and probably the air spring suspension if it has the seprate control module in the trunk. If it is not the limo and it has posi you can use the carrier.
                .... the axle will be more or less a direct swap, no need to rip the carrier out.
                  the 4.6 mount brackets will bolt to the box frame
                  i took mine out when i did the 5.0 conversion and bolted the box motor mounts into the 92 frame
                  the trans mount and crossmember is different need to use the town car one
                  the rear will bolt in, just have to run brake lines and hook up e-brake cables
                    I am not an expert on this but if I rememer right from others on this forum, you can swap the whole rear up to and including 1997. Do I have that right?
                      correct jay
                        Within driving distance of me, on CL are a few drivetrains (engine & tranny). 1 302 drivetrain, $900. 1 4.6 drivetrain, $500. 1 460 drivetrain, $600.
                        I think it all depends on how much you value your time, if you're able/going to be doing your own swap, or paying someone else to put it all in. The wiring of a non-stock drivetrain into a car, or throttle/shifter linkages etc. can be a bitch, but if you like having something different, or surprising, or fuel-economy-be-damned-460-power, maybe it's worth the hassle to go do something different.
                        As long as you're totally committed to getting it done, not ripping the old crap out, getting the new stuff part-way in then giving up and letting it sit to rot. Have enough money set aside and a good mechanic that could finish the job for you before you start the project in case other things come up that prevent you from completing it in a timely manner.
                          If you're using TownCar drivetrain on non towncar panther, keep in mind you'll need a custom driveshaft made, or find a Mark VI two door...
                            Thanks again for the input everybody. this is sounding a little more doable with some extras.
                              Just because you can doesn't mean you should. For the money, you can install an Explorer motor and have more horsepower and torque. You are going to spend money on custom wiring and the fuel system. Exhaust will cost you more.
                              What are your goals? If your goal is a cheap replacement engine, you will not attain that goal. If your goal is more power than stock, you will have that but less power than if your stayed with a 302 upgrade. IF your goal is to have something different, you will have that but at a significant cost $$. Do not go into this believing that it is a cheap and simple swap for someone who is not already experienced in engine and transmission platform conversions.
                              You will likely have to do some motor mount fabbing. If this is beyond your ability then this is not the conversion for you. You could convert to a 351W for less money and less headaches.
