140mph cluster and police swaybars.
    I have a police speedo and both police swaybars off 89 cop crown vic. $180 for all.
    “Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
    any cop rear control arms?
      I will get cop control arms tomorrow.
        speedo
        Here's a cluster picture.
          Added: box body cop rear LCA's. $80 for both + shipping.
            Are the control arms made stronger then the stickers? Any pics?
            The Best
            Past and Present Any Questions...................
              Cluster sold. Still have sway bars and lca's.
                both lca say dura 4216931 and date 1 89.
                  Still have the rear bars and control arms?
                    Yep.
                      Here's a pic of LCA's.Click image for larger version
                        how much for the LCA and sway bars?
                        1989 Lincoln TownCar with Mark VI Front Clip, 3G Alternator, Hella Headlights, Dual exhaust, FlowerMaster 70 series, '90 tubular exhaust manifolds, 1" Phenolic Spacer, Bored out stock EGR Spacer, 60mm HO TB, CVPI Power Steering Box, 18" Niche Alloy's, Monroe Sensatracs.
