pic of factory vs spicer idler arm SAFETY ADVISORY
    Hi,
    Iv'e been away for a while because I got a Subaru BRAT as an additional hobby. I still have my 91 GM, best handling and quickest car I have ever owned.
    Faster that the Torinos (351C 4v) and Mach 1's I owned in the past.
    I have been doing some extreme driving in the GM such as hitting curves at 70 then nailing it in the middle of the curve and riding on rails. I just recently replaced the factory idler arm with the best NAPA could get which is built by Spicer.
    If I would have realized how thin and inferior the factory one is, I would not have pushed so hard in the curves. My philosphy was curves are for speeding up and not slowing down since most of the front end was redone along with adding 245/60/15 T/A radials on 15 x 8 inch plain rims, Bilstein shocks, ES control arm and ES sway bar bushings, new upper and lower ball joints and PI sway bar . I consider myself very lucky the factory idler arm did not snap. In my opinion, if you are going to ride on rails make sure your front end and rear suspension is the best it can be. Its not worth risking your life all in the name of having fun I am gonnal replace both outer tie rod ends, the Pittman arm and install police rear control arms and the rear sway bar this weekend. That leaves only the inner tie rod ends left to replace.
Name:	iphone 1-3-12 291.jpg
ID:	1299358Click image for larger version
Name:	iphone 1-3-12 292.jpg
ID:	1299359Click image for larger version
Name:	iphone 1-3-12 294.jpg
    holy CRAP that's beefy. It's hard to tell it's even the same application.
      yea the factory ones sucked, but they lasted 20 yrs.
      only problem with oem ones i have ever had is the bushings wearing out and getting sloppy.
        yup. the one on my 88 was squishy bushings. other than that, it was fine. Replaced with a greaseable one (grease fittings at both ends... no bushings) and the steering is much tighter.
          Honestly the hollow tie rods scare me more than the idler arm does. Those aren't very thick to begin with, and they are usually full of rust. You can collapse those things with a pair of pliers if you put some effort into it.
            I got the Pittman arm on, outer tie rod ends, rear lower control arms and rear PI swaybar. Also had an alignment.
            Now if only this rain and slick roads will go away so I can try the new swaybar.
            I do need to replace the upper control arms in the front at $80.00 labor per side. Any suggestions to manufacture? I want the best since I like to push it in the turns. The person who will do the work said to either replace the whole control arm or if I can't find it, to bring the bushings and ball joints. I'm thinking ES bushings and not sure which ball joint though.
              80 dollars labor per side for control arms? What's the shop rate, 5 an hour?
                bah... uppers are easy to swap. I can do both inside an hour if the ball joints aren't completely rust welded to the spindles. and I don't even have a lift. Now bushings and ball joints take longer to do since you gotta pull more individual items.
                  Pressing the bushings out blows. Doing poly bushings is cake, but if you're doing rubber its something of a pain in the ass. The annoyance is the rivets on the ball joints. Honestly, if you're this far into it and you want the car to handle, go big brakes. It gives you a forged upper arm instead of that stamped steel thing, there is a much larger range of adjustment to the suspension, and the brakes are significantly better than the stockers. It requires a 16" wheel, but less sidewall also will tend to handle better than more sidewall so theres a performance incentive there too.
                  Another plus, late model upper arms do not rivet the ball joint in.
                    If you push it hard often expect to replace idler arms a lot. Mine have play after 5000 miles.
                    1989 Grand Marquis LS
                      looks stronger but is it? ya never know
