In 89, one flasher feeds the turn signal side of the switch and the other flasher feeds the 4way side. I believe this deals with the four way drawing twice the power of the turn signals. Also you need one flasher to control the 4ways to make sure all four flash at the same rate. Given this I am stumped.
No turn signals.
open ground somewhere most likely, or an internal short in the motherfucker switch in the column sounds most likely.86 Lincoln Town Car (Galactica).
screwed multifunction switch. It directs the power from flashers. or the connections into the multifunction switch are not all good.
Ok tried this: I unplugged both connectors from turn signal switch plugged the flasher in and it still flashed. I think im getting closer somewhere.“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
Where do white with blue lines wires lead to from flashers? I tried putting 2 prong flashers in 3 prong connectors and if those wires are not connected the blinkers dont work.“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
No white with blue in the 89 diagram except comming out of the turn signal switch. That goes to the right indicator on the dash plus the right front exterior signal and cornering lamp.
The only way I think you could get flashers with the switch completely disconnected is if there is a short in the harness somewhere between the 4way flasher and the switch. Problem with that is that it would have to be shorted to 4 different wires for all four lights to flash.
If the 86 wiring is different then......03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
time to trace wire. definitely looks to be a short bwtween the fuse box and the multifunction switch. at least it's not a crap ton of wire to sift through.
---1990 Lincon LSC., 5.0 H.O., 55,000 ORIG. miles, 3:73 Posi, Bullit rims, 3G alt., 2.5" full-back exhaust, Mark 8 elec. fan, Flowmaster mufflers. My DD
I can not really read those pics, but is it two fuses to separate flashers then into a combined turn/4way switch assembly, then four separate hot outs from the switch to the four corners of the car?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
yes, 1 fuse powers turn signal flasher and brake switch. the secound fuse powers 4-way flasher and supplies power to the gear shift neutral switch.---1990 Lincon LSC., 5.0 H.O., 55,000 ORIG. miles, 3:73 Posi, Bullit rims, 3G alt., 2.5" full-back exhaust, Mark 8 elec. fan, Flowmaster mufflers. My DD
It would have to be a very special specific short to power all 4 flashers without the switch installed given that there are 4 wires out of the switch. Are there 4 hots out from the switch in that diagram?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
the way i'm reading it there's 4 coming out of the switch, one for each corner of the car. if you save those pics to your computer then open with paint or what ever else you can read it better.---1990 Lincon LSC., 5.0 H.O., 55,000 ORIG. miles, 3:73 Posi, Bullit rims, 3G alt., 2.5" full-back exhaust, Mark 8 elec. fan, Flowmaster mufflers. My DD
So they are basically the same as the later model.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
I found the problem it ended up being one of the smaller fuses under the steering column. I still don't know what are those 2 flashers are for (they are both are 3 prong and located/bolted up higher and being the fuse panel).“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
the 2 smaller ones are relays for the cornering lights.
