Dash Lights/Parking lights no worky
    Ok 2001 p71 like the title the dash Lights and parking lights aren't working. I've check the fuses and there good. Now I don't know how to determine if its the switch or the lighting control module. I've taken out and apart the switch and didn't see anything obviously wrong with it. Does anyone have a wiring diagram or possibly no what wires I should jump at the switch to see if that is the problem?
    1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
    The LCM controls that too... so if the autolamps turn on and the parking lights don't... it's the LCM or the connections to it.
      Well.... I replaced to LCM and the switch. Check all the wiring and connectors I could get ahold of. Help I'm outta ideas!
        now you're down to wire tracing... unfortunately. check every harness you find first for bad connections and every ground wire to make sure it's actually bolted down.
        the connections in the harness may LOOK fine, but make sure they're actually grabbing when connected as well. If you don't see good contact lines on the metal... it's not making good contact.
          A new LCM & switch?
            Do you have a good wiring diagram for an 01 I can seem to find a good one on line. And yes I put a new LCM & switch in it.
              ground
                Originally posted by marquis_82_withneons View Post
                ground
                And I will see about a diagram
Name:	2000 cv lcm 1of3.jpg
ID:	1271892Click image for larger version
Name:	2000 cv lcm 2of3.jpg
ID:	1271893Click image for larger version
Name:	2000 cv lcm 3of3.jpg
                    Thanks
