Somebody was having them a BAR-BEE-QUE. Remember the wiring harness in the driver side channel was toasted all the way back through and the rear seat wouldn't come out so it didn't get replaced where it was pinched. While that harness fixed the park lights (fronts never worked again after driving home) I noticed the fuel pump was running the rear defrost! Unplugged rear defrost, and drove it.
1991 GM LS Part Out
mmm mmm mmm toasty
I know about the bolts, it's the nuts I want to know about. are they welded/pressed/captured/extruded? If it requires cutting stuff out of the c-pillar, don't worry about it, just post the pics. Bolts I can get at a local hardware store pretty easily. I was just thinking it would be nice to have the nuts as well if they're not welded in. I also want to know the positioning as well.
though I could use the coat hook and screw for the driver side of my 88. I think the interior is the wrong color, but at this point, with my 88, I could care less. If I could swap all of your interior into my car, that would probably work the best, but you're a bit far for that. How are the visors? I could use those too. Both of mine are about gone.
yes please on the visors... don't care about the electrical on them... I can fix that later if I want. The coat hook, don't worry about. also, those nuts on the C-pillar are pressed in blind nuts, not welded. I figured they were something like that. I'll just drill and fit something behind as best as I can. I seriously didn't want you to bother with cutting that out and just wanted the pictures of the naked c-pillars. Thanks muchly though. I know exactly what I need to do now to put the 3-points in my car now.
