need help identifying parts on my 1980 grand marquis
Results 1 to 12 of 12
Thread: need help identifying parts on my 1980 grand marquis
    Default need help identifying parts on my 1980 grand marquis
    Hi! I have a 1980 grand marquis with the 302 in it.no am trying to figure out what transmission is in the car along with what rear end.. I thought it was an aod in it but the linkages where the kickdown cable ( I added a lokar cable instead of the rod) attaches to the trans looks liken a fmx trans.. But car says automatic overdrive on rear windows. Also I want to put a limited slip differential in it but I think its a 8.5 rear end. I believe everything the same as a 8.8 though. I am familiar with 8.8s due to my 1988 5.0 GT mustang. Any help would be awesome!! I also would like to swap rear disc brakes and upgrade to like 3.08 gears.
    The plan is for a turbo 351w this summer some time.
    Thank you all!!
    Proud Owner Of A 1987 Mercury Grand Marquis! miamibob's Avatar
    Apr 2011
    South East Florida
    4,478
    Far as I remember it IS an AOD in that year. Not sure about the rear end though.....
    Apr 2011
    South East Florida
    4,478
    More research, however, does show C4/C6 and FMX in some of the vehicles. Sorry but I am sure that doesn't help much!
    Play me something funky! marquisman's Avatar
    innisfil, ontario, canada
    10,114
    Welcome!
    These era of panther came with both C4-3 speed and AOD-4 speed. Some did come with a FMX. Do you have a 321 gear indicator pattern? Or OD,D,1 pattern? Most likly, you have an AOD. The trans pan is the quickest way to identify it for sure.
    As for the rear end, the door jam VIN tag will list the axle code but, best place to look is at the tag attached to the diff. And yes, 8.8 and 8.5 housings are the same. Just need the 8.8 guts.
    Thanks for the replies so fast!! The gear indicator says 1-3-D. But I'm used to an overdrive trans having a circle around the top most d meaning overdrive. Mine just says only has one d and no circle around it. By the look of the kickdown linkage that goes thru the trans housing, it looks like its an fmx. But if I remember correctly, i thought it was an aod per the pan bolts... I'm all sorts of confused lol.
    Thanks for the help on the rear end! I would like to swap disc brakes and add limited slip and 8.8 gears.. I can get the code number off the rear end later today.
    This car had 85k original miles, bought from the original old lady that bought it new lol. I put a 289 hi po 4 barrel intake on it, big can, headers, full 2.5 mandrel bent exhaust, and got rid of all the vacuum emission stuff.. Its a great car, just looking for more power later on.
    After further review.. it has a white circle with a black D in the middle of it.. so mb that is an overdrive d?
    10,114
    Yea, it is most likly an AOD I for got they use a 3 instead of D in early panthers. 3 is the same as D lol and a white circle, with a black D is overdrive(that dident sound right lol). My lincoln is like this too.
    And we live for pictures here
    Lol!!! Okay..i will take a picture of it, but i am unsure of how to post them on here.. i will mess around with it and see if i can get it figured out. Thanks!
    10,114
    No problem. I should add though, make sure that TV cable is adjusted right and does not losen up any. It dont take much for these AODs to burn up, especially the early production units. From my experience and many prolly will agree, a higher(more max) adjustment will help.
    And for your pics, using a image hosting site is best. That way you just have to copy the URL, in the pic uploader.
    "The finder of unobtainium and other magical items" zoomie's Avatar
    Jan 2009
    Eustis florida
    3,059
    for a decent gear , you can nab a rear from a lincoln towncar limo, they have 3.55 gearing and traclok already installed, you can also find the "k" code axles in towing package wagons and towncars as well, a good indicator is the dual exhuast, but not always. limos also have been varified as having 31 spline axles as well.
    I am not sure what a tv cable is.. i ordered the lokar fmx kickdown linkage, because looking ay the installation paper, the fmx has the same exact linkage as what my transmission has.. i will post pictures later of the trans along with the gear indicator
    41,825
    TV cable is what that Lokar thing is. On a 1980, it would have used a rod. The multiport injection models starting in 1986 got a cable to do the same job.
    The AOD is descended from the FMX, so its entirely possible those parts look highly similar. Its also not impossible that your car does not have the original transmission in it. Does the trans pan say Automatic Overdrive on it? If not, it may not be the original AOD.
Tags for this Thread
