Looking for Headers
    Here is a picture of the headers installed.
      i have the hedmans, after a few yrs the flanges warp and they leak.......bbk's are much better
        Originally posted by 88Vic View Post
        Does anyone one here have modded longtubes on their box?
        Yes, and it's not worth it in the slightest.
          I imagine if you can fab them yourself it is but if you have to pay someone else the gains aren't worth the extra cost over shorties.
            I have a set of mid length headers here modded for a box just sitting here.
              I modded mine to fit. Cost wasn't why they're not worth it.
              Long tubes are a fucking pain in the ass no matter the car. They're not worth it on a build that don't require them because they take up so much space and get in the way of everything. After having two cars (one Ford, one Chevy) with long tubes I can safely say they're far too inconveniencing for me to give a fuck about them on a daily driver/street car.
                What mods did you have to do? Pics? Feel free to PM me...........
                Rodney Tolleson, me at the track.....future drag box racer!
                  I cut, rebent, and rewelded one tube, did some massaging in other areas, and also notched my engine crossmember in two spots. I have no pictures. It's not worth it.
                    LT headers are GREAT! if you don't mind the hassle of install and, if designed properly for the application, don't interfere with much of anything...unfortunately most make starter replacement a nightmare on SBF's. I've been toying with the idea of making a set of LT headers(from scratch) for a box for awhile and now that I have a running spare car that's been unmodified, I'm wondering if there is enough interest in longtubes to justify the cost of me prototyping a set. When properly sized, LT's improve power everywhere, problem is most people go too big on primary size...and they do wonders for making an engine sounds deeper and meaner.
                    Regardless of interest, I will be making a set for my tudor(351W/T5) eventually, but that's a much less common combination than a standard plain-jane 302/AOD.
                    -Don
                      My car sounds awesome with the long tubes, I'll say that much. The Monte sounds hardcore too. I can live without the sound if it also means living without the hassle though. My El Camino has a far healthier motor and stock manifolds and it sounds better than either one because I know it's got the bite to back up the bark.
                      and if you go looking to make your own, do the world a favor and use a nice, thick, single-piece head flange instead of four separate ones. God, so much hassle could be avoided if some of the shittier companies just used one-piece flanges.
                        Originally posted by CheeseSteakJim View Post
                        ...and if you go looking to make your own, do the world a favor and use a nice, thick, single-piece head flange instead of four separate ones. God, so much hassle could be avoided if some of the shittier companies just used one-piece flanges.
                        AGREED! The individual flanges are okay on the first install...but after they've been thermal cycled, the will NEVER fit again...nobody wants to dick around with a prybar to get each primary tube bolted up!
