I'm a firm believer in "P" heads....Also, the intake ports on the gt40's are slightly larger than HO, I always order intake gaskets for an explorer when I do the swap and they match up almost perfectly, 10minutes with a simple tool like a dremel would allow perfect port matching...and port matching the intake to the heads is worth it's weight in gold if you can do it yourself. I had an '88 Cougar with a stone stock HO and a 5 speed, cooked the heads and replaced them with '96 GT40 (non-P) heads and an explorer intake and 1.7rr's. That car was an animal afterwards...until it ran out of fuel pump at 3000rpm...before all that, it was around 4200rpm....an 88lph fuel pump was not nearly enough.
-Don
-Don
