Rizzo's Jmod video
This is a sticky topic.
Rizzo's Jmod video
Last edited by 88grandmarq; 05-21-2013, 10:17 PM.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
I rebuild AOD/AODE/4R70W/4R75E transmissions....Check out my Facebook page: https://www.facebook.com/pages/North...48414635312478Tags: None
- Stuck
Currently prepping for my first J-MOD (on a 2000 MGM) and have a gasket query. The gasket that you see when you take off the valve body is called a "separator plate gasket", p/n 7C155 (on the fordparts.com site). This one is apparently the same for all whales. The gasket between the valve body and the separator plate is called the "valve body gasket", p/n 7D100. This one is obsolete. The fordparts.com site only shows the 7D100 up to 2000. Starting in 2001, they use p/n 7C155B for the "valve body gasket". Curiously, the obsolete and current ones both show as being for AOD-E/4R70W/4R75W. Is the 7C155B backward compatible? Or should I stock up on the few 7D100's that I've been able to find?
Originally posted by IPreferDIY View PostCurrently prepping for my first J-MOD (on a 2000 MGM) and have a gasket query. The gasket that you see when you take off the valve body is called a "separator plate gasket", p/n 7C155 (on the fordparts.com site). This one is apparently the same for all whales. The gasket between the valve body and the separator plate is called the "valve body gasket", p/n 7D100. This one is obsolete. The fordparts.com site only shows the 7D100 up to 2000. Starting in 2001, they use p/n 7C155B for the "valve body gasket". Curiously, the obsolete and current ones both show as being for AOD-E/4R70W/4R75W. Is the 7C155B backward compatible? Or should I stock up on the few 7D100's that I've been able to find?__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
I just paid less than $10 for the two gaskets, though probably about $7 for gas. My big concern is compatibility. The 7C155 has apparently not changed over the years, though I'm no expert. The place I got the 7D100 from had a different version of a 7D100 for 2001, with a few different holes. Does anyone know if year-to-year variations are common?, or whether 2001+ are the same? (If/when I get another whale or two, I'd prefer 2002, 2004, or 2006+, unless I get a really good deal.)
FWIW, here's a list of some tranny variations over the years:
http://www.idmsvcs.com/2vmod/tranny/...vic/index.htmlLast edited by IPreferDIY; 04-29-2015, 12:39 AM. Reason: found original link instead of mirrored link
DO NOT use a separator plate gasket for a 2001 up in your 2000 valve body !!! it will damage the transmission
you can a gasket kit for cheap; http://www.transmissionpartsusa.com/...-00027137k.htm2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Originally posted by 88grandmarq View PostYes, the gasket between the valve body and the separator plate are different for 2001 and up. the gasket between the case and the valve body is the same 1996 and newer 4R70/4R75.
FWIW, it looks like the full OEM part # for the one between the separator plate and tranny case is 1L3P-7C155-AB.
With any luck, I'll finally get around to doing my J-mod and various other things in August. When I do, I'll make a point of measuring all the holes noted in the original J-mod specs and seeing where everything's at. At this point, I'm figuring on leaving the springs in based on various comments I've read. I'm figuring it'd be easier to live with not enough than too much.
Here's a link to my thread about my experience if anyone's interested:
http://www.grandmarq.net/vb/showthre...ound-186-350km
