Results 1 to 14 of 14
Thread: pleading ignorance, belt question
  1. #1
    I post a lot... porschpow's Avatar
    Dec 2009
    Hamilton, NJ/Flanders, NJ
    1,620
    Default pleading ignorance, belt question
    Ok, I think I narrowed it down to the belt that goes around the ac pump (not the power steering and alt), how easy is it to change???? I need to change it, its so annoying
    -1973 Volkswagen Bus Westy
    -1986 Honda Magna 700cc
    -2011 Subaru Outback
  2. #2
    ... mrltd's Avatar
    Jun 2005
    East Liverpool, OH
    12,891
    pull alt belt off, there are two bolts holding the tensioner one on the back, and one of the front. It's not too bad.
  3. #3
    Dec 2009
    1,620
    is the tensioner the pulley right below the one for the condensor pump one (the one on top)? So there is a bolt in front, ...AND IN BACK?????
  4. #4
    Jan 2007
    Westmont, New Jersey
    10,361
    Yes, that's correct. 14 or 13mm in the back. 14 or 15 at in the front for a pivot. There's actually a square to put a belt tensioner tool in, but you'll have to have your other hand on the back bolt to tighten it to hold tension.
    I've always had a little issue putting the new a/c belt on fitting it between the water pump pulley and the big lip in the middle of the crank pulley really sucks.
  5. #5
    ... mrltd's Avatar
    Jun 2005
    East Liverpool, OH
    12,891
    14 mm on the back and the front. Once you see how it work it should make sense.
  6. #6
    Dec 2009
    1,620
    Ok, so you don't have to use a tensioner tool (AKA tire iron) to tension the belt?
    Those bolts are on that pulley right below the AC condensor (top pulley)?
  7. #7
    Go take a bath! Go milk your goat! Piece-it pete's Avatar
    Mar 2009
    Cleveland. We rock.
    3,936
    Looking around I found this:
    I only recently found out about the 1/2 drive to tighten the tensioner, and never knew the combo wrench on the alt (I always used a tire iron too).
    Pete
  8. #8
    Dec 2009
    1,620
    Lol how about that, This drawing is awesome!!! Thanks guys!
  9. #9
    Jan 2007
    10,361
    Quote Originally Posted by Piece-it pete View Post
    Pete
    Where did you find this?
  10. #10
    Mar 2009
    Cleveland. We rock.
    3,936
    I googled '1985 Grand Marquis belt' and looked at images.
    http://www.justanswer.com/uploads/VL...74727_Belt.jpg
    Pete
  11. #11
    ... mrltd's Avatar
    Jun 2005
    East Liverpool, OH
    12,891
    the "adjustment torque bolt" is the one on the back side of the bracket.
  12. #12
    Dec 2009
    1,620
    Interesting, i def like the 1/2 breaker bar being used as the tighteneer for the belt tightness!!. It seems like its somethign i could tackle in an hour
  13. #13
    Dec 2009
    1,620
    Should I be cleaning the pulleys with something prior to me putting a new belt on????
  14. #14
    39,101
    only if they are rusty or coated with something. If thats the case, a wire brush should do the job just fine.
