For those who swapped in the 351W in favor of the 5.0L; what did you use for a power steering bracket? I guess you can add the other brackets as well (smog pump, alternator, a/c if applicable). For me right now is the location of the power steering pump is important. The 351W that I have has it mounted much higher than the stock 5.0L lopo. I see in JEGS that they have a power steering bracket for the 351W swap that allows you to swap from the 5.0L? Although this is for the Fox body Mustangs, has anybody used this for the our box Panthers? Thanks
http://www.jegs.com/webapp/wcs/store...97-M-8511-A351
