Is it possible to have failed head gaskets and there be no symptoms other than mysterious coolant loss?
Head Gaskets Gone?
i will second this.. my merc has mysterious coolant loss too. i have a slightly bad heater core.. but not terribleCharlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
unlikely. Slow coolant loss is usually a hose or radiator or something that leaks only a little and steams off before it puddles. Look for green crusty stains around things. A slightly bad heater core is still a leak.86 Lincoln Town Car (Galactica).
egr spacer has been known to cause that too (on lopo 5.0).
I had a slow leak on my 5.0 - never left a mark on the ground, but while looking under the car, you could see where coolant was seeping past the water pump gasket. Removing the water pump, you could see where it failed internally.-Nick M.
Columbia, SC
Is possible. The coolant is going somewhere. You can have a slight headgasket leak, beginning failure, where the coolant mixes with the exhaust ports. I've had cars where the exhaust entered the cooling system and caused the coolant to simply bubble out the overflow.
Ask anyone that owned a Cadillac Northstar. In the beginning stages of head bolt/gasket failure exhaust will enter the cooling system only when you stress the motor. Such as entering the freeway. You mysteriously lose a little coolant out the overflow which evaporates before it hits the ground. Since we have dummy temp lights you wouldn't notice a temporary and slight temp fluctuation.sigpic
GrandestMarquis
that's a prime indicator.
thats where mines going too. but i dont want to take my dash apart to change that yet. ill have it apart soon enough and when i do ill change it. that and i think some MAY be in my oil.. although its a VERY small amountCharlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
Originally posted by marquis_82_withneons View Postthats where mines going too. but i dont want to take my dash apart to change that yet. ill have it apart soon enough and when i do ill change it. that and i think some MAY be in my oil.. although its a VERY small amount
What else should I have the mechanic do with the instrument cluster out?
The core is not expensive - it is the labor to get the dash, ect... apart to get to it and put it all back that is expensive.
