Quick question
    Quick question
    Was looking at Craigslist at work this morning and saw an 85 tbird with the 302 and they had a pic of the engine. Regular air cleaner like what was originally on my cfi motor but it has an EFI sticker on it. I've read the efi swap thread on here and I guess that's sefi? So how is 1985 efi set up? Is it like cfi but with mass air flow sensor instead of speed density?
    GrandestMarquis
    CFI is EFI, just a basic EFI. The S in SEFI stands for "sequential", which basically means that there's an injector for each cylinder times with the opening of the intake valve for that cylinder. Much more advanced and efficient. CFI is still Electronically controlled Fuel Injection, and Ford marketed it that way. The C stands for 'Central', as in the injectors aren't coordinated to the cylinders and are located before the air splits off to each cylinder.
      CFI/EFI.. central fuel injection, 2 injectors on a carb controlled by the computer.
      SEFI and up... injector for each cylinder controlled by the computer. basically the same idea you see now on cars just more advanced.
      feel free to correct me if im wrong. im not TOO familiar with cars after the CFI
        Okay but does efi have a mass airflow sensor and if so I'm to assume it will play better with engine mods?
        GrandestMarquis
          Both of those are EFI. Anything without a carb is EFI. There are three types of EFI- Central, Sequential and now Direct where the injector dumps directly into the combustion chamber as opposed to the manifold. Any other types I missed?
            In panthers, SEFI was available in MAF and Speed. Not sure about CFI but since it was older tech I would guess speed.
              yeah nothing with the carburetor-type air filter is MAF.
                Okay, so what I saw on the tbird is exactly what I have under my hood but with a different label. Nice
                When I saw that I thought there was another version I was unaware of.
                Thanks.
                GrandestMarquis
                  Theres actually another, broader category. Multiport Fuel Injection. Panthers have this, as did the trucks. Difference is that the cars had sequential, where the trucks were batch fire. They had 8 injectors, but only 2 injector drivers. Each driver fired a set of 4 injectors. It was usually one driver did 1, 4, 6 and 7, the other did 2, 3, 5 and 8. Why they did that, I have no idea. Sequential is slightly more efficient since the fuel is fired on the intake stroke only. With the batch system, the fuel usually ends up puddling on the back side of the valve until it opens during the intake stroke so you end up with a less effective atomization.
                  The mass air thing isn't really dependant on what sort of system you ran. The SEFI in the non-Mustang cars were almost all speed-density, which does not use a mass air sensor. Some of the trucks had a MAF, but I think that started in 94 or something. 91 California Vics were mass air, but none of the others were. I don't know of anyone who ran mass air with a throttle body type system, but its not impossible that it exists.
