Wyandotte
    Wyandotte
    Latest ride is a 87 Country Squire. Had it for a few months now. 3and 4 gear are out just been driving it around town 45 and under except going doown hill.
ID:	1300704Click image for larger version
ID:	1300705Click image for larger version
    Cool. Just tell everyone its got a Powerglide and really low rear gears.
      Nice. My dads 88 colony park only had 1st and 2nd for a few years. Let me tell ya, the inside of that engine is spotless
        Cool. I love wagons.
          My Lincoln only has 1st and 2nd, I fried the others. Together we have a whole transmission
            I have 3 good transmissions only one spare converter. Have 2 other converters but am a bit worried about using them as they might have got some dirt in them lying around. Have a 4th trans that might be a bit weak runs good but never felt quite the same after a few dyno runs.
              Came with 4 Michelin wore out an crack tread and side walls. Things fixed so far. Dizzy crapped out on me were I park it. While replacing it noticed the thermostat gasket had let go at the same time. Someone had used clear silicone and with part of the gasket stuck it back on. Looked like long ago repair. Just for snicks replaced the upper rad hose with a better looking used one I had. Untill last week the only other fix was the tailgate window adjustments in another thread. Passenger window motors are not working. Drivers and rear window locks are not working.
                Sort of curious where you're going to take this car.
                    You can send that weak one my way, rather have a weak one that shifts into all gears than my current powerglide. Need to get my Lincoln back on the road before someone makes me an offer and turns it into a derby car.
                      Last week swapped out the shocks and straight wt wagon over load springs that were installed in Casper the stock 2 door. Reinstalled Caspers stock springs with no shocks. Moved Casper out and jacked up the wagon. Didnt know the wagon shock tops were more difficult to access. Oh well cut the ends off with a grinder. Installed the HD springs, shocks are RV units that suited the static ride hight. Then mounted some 295 50s on the back with some steel 15 x 10 rims that came off the old blue car. Set the wagon down and brought Casper back in this time installed the stock springs out of the wagon and swaped the cracked front tires on the wagon withthe tires out of the trunk of panthers I have ouned. Never been on the ground before so like 0 miles on them but old.
ID:	1272600 spring at top of pic is stock one
                        First time I saw this thread I thought "what's going on in Wyandotte? If I'm not busy maybe I could make it." then I realized it's the name of the car.
                        Nice looking wagon by the way.
                          I just got back from MI Westland area for the most part
                            Pic of the rear wheel and tires. With some mods I expect to install the stock hubcaps.
Name:	TOLEDO TRIP 005.JPG
                              Love the wagon..........whats the BS on those wheels?
                              Rodney Tolleson, me at the track.....future drag box racer!
