1992 Mercury Grand Marquis
1992 Mercury Grand Marquis.
Upgrades: Big Brake Upgrade, digital dash, Custom ignition Switch system, sequential tail lights, Teflon Fuel lines, LED interior lights, rear end rebuild with limited slip.
Future upgrades: 5.0 swap, 4r70w swap, aluminum driveshaft.
Its awesome you are doing all the assembly work. I am interested in seeing when you get your solid lifter, the process of checking PTV clearance. Maybe that is something you can film?~David~
You can actually make a solid lifter from a stock one. Never done it but basically you take it apart and flip something over.
http://www.allfordmustangs.com/forum...asurement.html
nice cheap option if you're replacing them anyway. I probably ought to save one of the good ones from my engine and do that with, just so I know I never need it. I have that pushrod length checker tool that I made for the same reason. Annoyingly with that I found out that no dimension you can measure on a pushrod with normal tools matches up to the dimension Comp pushrods are sold as.
Those type clamps are nice on the bench, but vastly easier if you've got a head stand. You can buy them or knock together a functional equivalent from some scrap lumber and allthread easy enough.
https://www.amazon.com/Moroso-62080-.../dp/B000COS59M
The only time I did a set of heads myself off the car I was able to use a set that a friend had. I wouldn't buy a set to use once though.
http://www.diyporting.com/E7OV.html if you're interested in doing some massaging on the heads.86 Lincoln Town Car (Galactica).
Originally posted by 87gtVIC View PostIts awesome you are doing all the assembly work. I am interested in seeing when you get your solid lifter, the process of checking PTV clearance. Maybe that is something you can film?
Will do. I have been filming most of the assembly of the engine. Just haven't gotten around to actually editing it.Last edited by pivichot; 01-13-2017, 10:15 PM.1992 Mercury Grand Marquis.
Originally posted by gadget73 View PostYou can actually make a solid lifter from a stock one. Never done it but basically you take it apart and flip something over.
Thanks for the links. I will be making a solid lifter from one lifter, but I threw out all the old ones. Crap. Well, I guess I will buy one more additional one. I didn't go so much into porting the heads because these are just going to be on the engine about a year or so. I want to upgrade to AFR heads, just didn't have the budget to buy them new. Never seen the stands, it would have honestly helped. I guess I will buy them for the next engine build. My dad wants me to rebuild his engine after I finish mines.1992 Mercury Grand Marquis.
PM me an address, I've got a used one that I can send you. They're likely hitting the trash otherwise.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostPM me an address, I've got a used one that I can send you. They're likely hitting the trash otherwise.1992 Mercury Grand Marquis.
How many chickens do you have to kill for the voodoo ceremony to make an AOD work properly? I couldn't find that spec in my drivetrain book.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostHow many chickens do you have to kill for the voodoo ceremony to make an AOD work properly? I couldn't find that spec in my drivetrain book.1992 Mercury Grand Marquis.
Just sum total. Curious if I have enough in the coop currently or if I need to take on some more before I consider attempting a rebuild on one.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostJust sum total. Curious if I have enough in the coop currently or if I need to take on some more before I consider attempting a rebuild on one.Last edited by pivichot; 01-21-2017, 10:54 PM.1992 Mercury Grand Marquis.
So, not so good update. The project is coming along and the budget is non-existent. Waiting to flip a car I bought. But, that is not the bad news, bad news is that I somehow made the oil pump crack . Apparently I listened to ARP on their torque recommendation of 45 ft-lbs for the bolt from pump to block and 24 ft-lbs from pickup to pump. The 24 ft-lbs was a failure. Will post pictures tomorrow but yeah. Need to contact arp and see what can be resolved. The kit I bought was the following one:
http://arp-bolts.com/kits/instructions.php?RecordID=491
and from there it takes me to the recommended torque spec for the 170,000 psi yield strength bolts. I am pissed. I used the correct arp bolt lube and it broke. The max it went to was 19 ft-lbs.
Also, one of the heads got scratched. Don't know how because I was careful. So, I need to disassemble it and take it to the machine shop. It is that bad. My finger nail gets caught on the scratch.
Not my day.
I do hope to at least have good updates next week.1992 Mercury Grand Marquis.
