about 2 months ago, i replace the alternator with a new one from NAPA because the old one was going bad. since then, at WOT at high rpm right before shifting, the voltage light flickers as well as my headlights. never did that when the old alternator was still good.
alternator voltage drop at WOT
2010 Toyota Camry "Traveller II "
54,xxx miles. New daily driver
2001 Lincoln Town Car Signature "Leroy"
rear cats deleted, 2" h pipe, dual 8" cherry bomb glasspacks
114k miles. Sold to my coworker.
1998 Toyota Camry "Traveller"
Dead and sold.Tags: None
Belt slipping?2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
belt slippage or rebuilt alt has crappy bushings. A clutch pulley will help that.
does sound a lot like worn belt. Check the tensioner to see if its in the normal range. Often it will show fully to one side of the range if the belt is stretched.86 Lincoln Town Car (Galactica).
Originally posted by tjc78 View PostBelt slipping?2010 Toyota Camry "Traveller II "
Dead and sold.
Originally posted by sly View Postbelt slippage or rebuilt alt has crappy bushings. A clutch pulley will help that.2010 Toyota Camry "Traveller II "
Dead and sold.
the clutch pulley for the alternators requires a special tool.
the clutch pulley is kinda spendy... between $35 and $65 depending on source.
Info on them:
best deal I found with a quick google search:
non-ebay deal with tool (slow to ship unless things have changed):
I have a feeling that even with shipping on the tool from FIP, the ebay one will end up being less out of pocket. I haven't checked though.
Originally posted by sly View Postthe clutch pulley for the alternators requires a special tool.
Info on them:
I have a feeling that even with shipping on the tool from FIP, the ebay one will end up being less out of pocket. I haven't checked though.2010 Toyota Camry "Traveller II "
Dead and sold.
that may not solve the problem... but it will help. Though, clutch pulleys only tend to last 30-50K miles... so what you end up not spending on alternator parts, you will probably spend on pulleys... unless you keep your foot out of it.
Originally posted by sly View Postthat may not solve the problem... but it will help. Though, clutch pulleys only tend to last 30-50K miles... so what you end up not spending on alternator parts, you will probably spend on pulleys... unless you keep your foot out of it.2010 Toyota Camry "Traveller II "
Dead and sold.
Just out of curiosity, when did Ford implement the WOT alternator shutoff? I know the Marauder had it in 03, but did that carry across to other lines as well and possibly at an earlier date?86 Lincoln Town Car (Galactica).
I think it matched the switch to the PI motors.
