97 Grand Marq owner here (hence the user name). The heater core messed up and the "mechanic" claimed he had to drop the dash to get to replace it. No problem there. Got the car back and NOTHING electrical worked except for the speedo and fuel gauge. Yep the turn signals, the HVAC, the gear selection light and wipers turn on but I have to shut the engine to stop them and they dont park at the bottom of the windshield. Please help me?
Can't Breathe with no Air
as for the cluster lights... pull the instrument cluster and make sure the harnesses are plugged in all the way. Also, check all the harnesses in the steering column and around the fuse box area. He probably stressed out some wires and/or didn't reconnect some stuff.
Originally posted by sly View Postas for the cluster lights... pull the instrument cluster and make sure the harnesses are plugged in all the way. Also, check all the harnesses in the steering column and around the fuse box area. He probably stressed out some wires and/or didn't reconnect some stuff.
I would try to get some of my money back, in time that may happen.
You may have to hire a lawyer, would that be worth it?
Do whatever makes you feel better and has a chance of getting you some justice.
But I would also get that car under a good shade tree or in a garage and take it apart.
Short of pulling the new core I would go as far into it as needed to figure out whats wrong
and fix it.
This sounds like the type of problem that takes a long time to resolve and until that happens
you'll be without unless you do it yourself.
just my
Dlc?
you mean the OBD-II Diag port?
Should be just up out of sight behind the steering column knee panel.Last edited by sly; 08-29-2013, 09:29 PM.
