hi, i am new to the forum and this is my first post.
i recently picked up this 88 grand marquis. im am the third owner, 98,000 original miles and all service records from a local dealership. i bought it with a bad water pump, which i replaced the day i bought it. due to the bad water pump, i didnt take out on the freeway during my test drive. after the water pump was replaced, on the way home i noticed it wasn't shifting past second gear. it didn't take long to find on this forum the throttle valve bushing issue. i checked mine, it was broken, i fixed it. the shift from 1 to 2 was greatly improved. faster and more crisp. but it still wont shift into 3rd or 4th/OD. everything else operates fine, and it doesn't make any funny noises or bumps/clicks/ knocks etc. besides the hiss from the dash which i have learned is the vacuum assisted parking brake release? i think.
so my question is, is a rebuild my only option?
i have a feeling this is the case, but would like to make sure and see what you guys think. i don't want to throw money and at it an not fix the problem. also, if this is the case is anyone on here from the pacific northwest? i am in Tacoma, WA and could use a recommendation on a good transmission shop in area. this is the first transmission issue Ive ever had with any of the cars Ive owned.
thanks for your help/insight
