I was driving to burger king A/C on music wasn't loud as i usually have it set and when i a couple of streets away from my house my car turned off so i turned it off and started it i could see white smoke so i drove as fast as i could parked the car popped the hood a ton of smoke was coming out opened it up and saw the 2g alternator on fire couldn't help but remember every 1 on grandmarq telling me to ditch the 2g. so i pour some of my soda and it went out then ignited, did it a couple of time b4 i remember the battery was probably feeding it (felt stupid...still do). the 2 charge wires don't look to bad i mean at the connection points on the harness but the rest of the wire looks perfect and it charred at the harness point not as bad as i thought tho i'll get some pics up as soon i charge my phone (pics or didn't happen) i can't help but feel like it's Christmas and my present is gonna be a nice 3g H.O. alternator i can already picture myself installing it ear to ear smile, ive been wanting to put 1 in since i found out it was possible and it looks like Christmas is coming early =)
TroubleMarq is down...
The lower one is usually the mothereffer. The upper one just have at it. Once you get the upper one off swing the alt down and I believe you can see where the lower bolt (LONG BOLT BTW) goes. Try squirting some pb blaster or equivalent on there.~David~
Good to hear you saved it before more damage could be done.1990 MGM: $50 E7 heads, HO cam, Holley SysteMAX lower intake, HO upper intake with an Explorer TB. LSC ECM. Lincoln logs into stock dual exhaust. K&N drop in air filter. Wide ratio AOD, 2400 converter with a 3.08 one tire fire out back. Car is less slow now. Then there's the '92 Beater. Dual 2.25" exhaust with shiny tips. Rumbles nice. Super slow. Burns oil too.
Was it the entire alternator or just the connectors that were faulty??
I have a known good 2g that i have a rigged cable to adapt to 3G wiring in case I need to rebuild a 3G and still drive the car while doing it. It's the original alt from my 88.
Don't worry about the charge wires if you're going to do the 3G swap. You'll be putting in a new (to you) charge wire anyhow. Also, the connector for the regulator is the same on 3G alts so it stays (as long as it's not damaged). www.delcity.com has the charge cable boot http://www.delcity.net/store/3:8!in-...ulators/p_1033
LateModelRestoration has the rest of the stuff....
Charge Cable
http://www.latemodelrestoration.com/...Power-Wire-Kit
regulator plug if you need a new one
http://www.latemodelrestoration.com/...onversion-Wire
stator connector if your current regulator plug is ok
http://www.latemodelrestoration.com/...mall-Parts-Kit
the 3g upgrade is awesome you wont regret it its easy youll like it good saveOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
Finally got it out and the thing looks fuccin charred to shit when the regular rachet and pb blaster wasn't doing it had to buy a 24'' breaker bar and ratchet adapters and it came out with ease it was almost a joke
i left the tags on because i planned on returning it and getting a blow torch but it's earned its keep
On older cars like yours the breaker bar will always come in handy.~David~
Didn't have a piece of pipe on hand to slip over the ratchet? Bah, never mind having more tools is always a good thing!2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
I have a small corner in my garage with a selection of different size pipes.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Originally posted by jaywish View PostI have a small corner in my garage with a selection of different size pipes.
