Page 45 of 45 FirstFirst ... 35434445
Results 881 to 893 of 893
Thread: Mod Box - 85' Grand Marquis
  1. #881
    Mar 2007
    North Las Vegas Nevada
    2,190
    Wheelbase is longer on the wagon than the sedan, just thought you should know.
  2. #882
    Hobbit
    Dec 2006
    Ontario, Canada
    1,188
    Same wheel base. It's longer out back though so the frame will need to be cut and extended.
    Some frame discussion here,
    http://www.grandmarq.net/vb/showthre...-Frame-Lenghts
    If I had to do it again I would've kept stock dash and not mod the firewall.
  3. #883
    I did find that they were the same wheelbase after scouring Wikipedia for dimensions and I have downloaded some diagrams, but havenít really started comparing measurements. I should only have to extend the tail end of the frame for support and bumper purposes, right? If so, do you recall there being enough similarities between the frames to use the wagon frame for this purpose? I appreciate the heads up on the dash, as I was considering taking a similar path that you took.
  4. #884
    Hobbit
    Dec 2006
    Ontario, Canada
    1,188
    Rear of the frame is pretty much the same all the way to 2011 so you can chop off the back of the new frame and weld a section of your old frame in its place.
  5. #885
    Hobbit
    Dec 2006
    Ontario, Canada
    1,188
    Rubber impact strips were starting to piss me off because one of them was peeling so off they go along with the push guards. I have a plan for eliminating the holes, will post an update once that's complete. I relocated the license plate to the center as well because I am OCD like that. No, I didn't drill another hole in the middle of the bumper. It's held in place on the bottom securely enough that another hole wasn't needed.
  6. #886
    37,299
    Whats the red car? 80s BMW something?
  7. #887
    Hobbit
    Dec 2006
    Ontario, Canada
    1,188
    91' BMW 318is. I've been working on fixing it up.
  8. #888
    Sep 2014
    Warren, MI
    5,316
    Hrm. I liked the front plate offset to one side, as it didn't clash with the bumper's lines, you know, the point in the center. Rub strip also looked great too as you've got a black car. Your car, your style though.
  9. #889
    Member EaOutlaw1969's Avatar
    Feb 2018
    353
    What a great project, your car should not be the POTM it should be POAT Panther of all time.
  10. #890
    20,734
    Between this one and LincolnLarry's 572 Cobrajet Town Car.
  11. #891
    Feb 2018
    353
    have not seen that one yet
  12. #892
    20,734
  13. #893
    Mar 2013
    New Haven, Indiana
    1,153
    Hey Bean, looking forward to that bump strip remedy. I have a base model without the strips and personally think the smooth look is better.
    Unfortunately mine are rusty and the only ones I'm finding are ones with strips so I may be going your same route. Do let's us know!
