1989 302 AIR Pipe leak
    Hi gents!
    On my '89 Crown Vic, the air pipe leaks somewhere behind the engine.
    The actual pipe that goes down to the cat, has already been cut short, and the hole welded shut in the cat. Now the pipe still leaks behind the heads.
    I read somewhere that the holes in the head are threaded, and I can delete those pipes and plug those holes with bolts? true or false?
    How much of a pain in the ars is it to do this?
    Pretty sure the intake manifold has to come off, correct? If so, that's fine, it needs valve cover gaskets as well..
    1989 Ford LTD Crown Victoria, 302, AOD, 160,000km (99k miles)
    To many other Fords to list!
    I haven't done this on a Panther, but the old 1981 5.0L V8 truck I had was not threaded. Guess is also depends on whether you have to meet any "air standards". Here in NC, we don't have to meet those strict air standards unless you have a 1996 or later vehicle with OBDII. Even then, they only interrogate the computer to see if you have any "DTCs". Not clear how many DTCs are allowed in certain year models but newer cars can have none.
      We do have emission testing here as well (same exact thing infact for 1996+ vehicles as you) but that air pipe non sense is only used when the engine is cold. So basically useless after it's all warmed up and wouldn't bother an emissions test, unless they would actually check if all that stuff was still there.
        I just removed my airpump and plugged those holes with 13/16 short bolts.
        “Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
          On my '84 Towncar I cut the pipe where it was broken and then connected it back together with a short length of heater hose and worm clamps.
            I took mine off and cut the pipes off the things that bolt to the heads. My dad pinched the ends and welded them shut. Put the end pieces back on the head to close the holes.
              You can put bolts in the heads (the passages are gonna be really carboned up by now), or take the pipe off and cut it, pinch/weld it shut.
                Or, take the pipe off, cut the ends off, flip them over, and bolt them back to the heads to use as blockoff plates. Those holes are probably so carboned up you'll never get the bolt to thread in. Its a pretty fat bolt too, 5/8-NC if memory serves here, and it may not.
                  Thanks for the tips fellas! I'm storing the car for winter, so i'll get this done in Spring.
                  How hard is it to do though? Do I need to remove the intake manifold to gain access?
