Well, I seriously don't know what going on with my coolant system.
It seems I have no pressure i nthe system.
I changed the coolant (winterized)
Changed to thermostat (and the small hose that goes with it)
Yet, the heater is not blowing as hot as it should
I check if the vacuum canister is holding a vacuum, it does. The vacuum hose that goes with it is sucking.
Yet the heater has no heat!!!!! Well no, the heat is there but not the hotness (max) that it should be
The Thermal block loacout switch is byppased. The vacuum hoses that went to it are SEPARATELY CAPPED OFF
I left the swtich in there cause the wires still going to it.
I finally took that wire harness off and crossed the wires. BUT I LEFT THE SWITCH IN. What I had noticed is that the coolant seemed to be leaking from the switch. I will have to go and buy a plastic hose connector.
BUT WHAT GIVES?!?!?!?!??!?!!?? The AC works, if I put in on cold, its great, just that the heater sucks!!!
