Modified Aftermarket Throttle Body for [Box] Panthers
    This is how I went about mod'ing the Trick Flow 75mm throttle body for the sbf engines.
    In this picture you can see the mod'd TB. The TFS TB and the stock Panther TB have similar setups except that the throttle body lever is bolted to the TFS unit and the stock throttle body lever is riveted. 1st step is unscrewing the 2 nuts holding the stock throttle blade to the shaft. Then you twist the throttle to WOT. When you have done this, grasp the throttle blade and pull it out from the rear.
    Now get some carb cleaner and spray the stock TB shaft. Remove the TPS (if not done already) and lightly hammer the throttle shaft down until you can't get the hammer any further. Then you will need to pull the shaft from the bottom of the TB. It might be difficult to move with all of the varnish. It will come out eventually.
    Once you have removed the shaft, you will need to grind the rivet/welded portion down to the throttle lever, being careful not to remove the material on the lever itself. When you have done that, you will need a hammer and a punch of some sort (pictured). Now you will need to locate the shaft section within the throttle lever material (not easy to do). I had to have my father find it, as I was pounding off center. Carefully whack away until the throttle shaft falls out of the lever.
    Now take your TFS (or whatever brand you get) TB and unbolt the shaft from the TB (you will need to remove the TB blade before doing this). Remove the lever and replace with the stock lever you just removed. Shove the shaft back into the TB and install the throttle blade. Hook up your TPS and there you go.
      I found the IAC for the '96 F4TE lying on the garage floor (not paved; only dirt) over the weekend. I don't remember taking it off,; unless it was removed and placed on top of the engine when I got it. I looked at it and realized that it would clear the EGR delete plate mounting flange for the throttle body cable bracket. The stock IAC would not clear the plate as it would hit the top bolt/mount. I ended up cutting the top bolt hole out to gain clearance. Had I found this earlier, I wouldn't have had to do that work; and the plate would look nicer (ugly cut).
        So I got a Lokar Ford AOD Hi-Tech Kickdown kit to replace the 28 year old TV cable for the CV. After staring blankly at it Saturday night, I realized that the retainer at the end of the cable comes off. So I was able to slide the kickdown mounting bracket off of the cable and replace it with 2 washers. One washer will mount in the back of the stock throttle/TV cable bracket and the other goes onthe inside to hold the cable in place. I will use elastic stop nuts to secure the cable. The other end that connects to the throttle body lever has a screw and a lock nut to hold it to the lever. I screwed it into the bushing to see how tight it is and it's tight. I will take it back out and remove the bushing, replace it with a couple washers, and screw it back into place. It looks like this may work. I will get pics of what I think may work.
          The other end (not pictured) connects to the transmission itself. There are instructions on setting the cable and adjusting the pressure. Hopefully this works out; that way we may have options when dealing with old TV cables.
            Tomco makes an IAC spacer plate for IACs that dont clear egr (since they have a 1 size fits all ford v8s replacement iac)
            Alex.
              Alex.
              As I discovered to my surprise, the '96 F-250 (where my engine came from) IAC clears the EGR plate. It points down and is shorter in length.
                Nice work!
                  Oh okay, I just found that plate on another forum. Yeah, that will definitely come in handy if the engine doesn't want to idle with the IAC. Just bypass it all together.
                    i'm leary of those lokar cable setups. tried them and have a strong dislike.........in my opinion you are better off sourcing a good used tv cable
                      don't mean to poop on your parade mang, looks good otherwise
                        Why's that? Any particular reason?
                        '93 T-bird
                        '03 Silverado ECSB
                        Missed:
                        '88 Mark VII
                        '86 CV
                          cable hardware is crap and the cable stretches
                          also on a carbed setup the geometry is not right without an adaptor that lokar does not make.
                            I am thinking of doing that as a backup and also source the brass bushings as well. Especially if the Lokar cables are prone to stretching. The JY I go to cuts the cables and just about anything that prevents them from yanking the engine out of the vehicle. Hopefully they have some new and untouched Panthers this Spring.
                              Triumph the Dog never apologized; neither should you. This is good practical information. I'd rather be warned by you than getting that phone call from my mom saying she's stuck in Camden and I need to come and get her. If the natives don't hurt me, she probably would. :o
