I picked up an awesome chrome plated ignition/steering column lock/chastity belt type thing from the junkyard a few weeks back.
It opens up like a clam shell then closes around the steering column and entirely covers the ignition lock cylinder and a shaft slide down and you place a master lock on her.
I have one problem with it....it has seen better days. Thing is rusting and chrome is peeling. How can I DIY remove the failing chrome?
Plan is to remove the chrome, paint it, felt the underside and add door edge guard to the sharp edges to protect my steering column cover.
Thanks
Thanks
