OK so I'm getting ready to start pulling my motor apart on my 98 gm to rebuild and install my PI top end (which I am porting and polishing heads along with five angle valve job). I am curious as to what potential this set up will have with a proper tune and without the tune. I believe I will attain around 10.5 to 1 compression with this set up. Also I have installed custom dual exhaust and modified my stock intake plumbing to work with a 4" cone filter that I am fabbing a heat shield for at the moment. I also am installing a 3.27 gear set with a traction loc. Any suggestions while I'm in there? And guesses as to power it can obtain both per and post tune?
what kind of potential does the PI top end on a non PI bottom end have?
I could be wrong so I hope some one else can verify this.
But I think a 10.5 to 1 compression ratio may require premium gas?
As for power, I can't say. But the gear change alone is going to be the best bang for the buck.Last edited by mcninetyone; 01-29-2014, 06:39 PM.
I installed just a PI intake on my non PI motor and noticed a pretty decent power gain.1985 LTD Crown Victoria - Currently restoring after she caught fire! CFI to SEFI to Carb swap, all custom wiring, Duraspark 2 ignition, Motorcraft 2100 Carb, slicktop, Shorty headers dumped before rear axle, 140 Speedo, 3G alt, And currently building an engine for her.
I don't know of anyone whose done a head swap... only intake or complete engine swap. I'd imagine that it would be a little better than the intake swap alone, but tuning would be required.
Originally posted by wannabep71 View PostSo no one can guest image potential?
Good luck
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
